11-21-2016
03:13
17:15
11-21-2016
03:13
17:15
Does the fitbit flex 2 come with a charger?
Moderator edit: Updated subject for clarity.
11-21-2016 03:59
11-21-2016 03:59
It comes with a charging cable that connects to a USB power source such as a computer or wall charger such as used to charge mobile phones. It doesn't come with a wall charger though.
Best Answer11-21-2016 03:59
11-21-2016 03:59
Best Answer01-21-2020 13:37
01-21-2020 13:37
Not sure how to charge
What plugs into the phone charger
Best Answer01-21-2020 23:55
01-21-2020 23:55
@Iflex you take your Flex 2 out of the band and press it into the charging cable that came with the fitbit as described in this help file: https://help.fitbit.com/articles/en_US/Help_article/1799/
Then you plug the other end of that charging cable (which has a USB connection) into a USB port on your computer. You can also use a wall charger but it must be one that has a USB port.
