05-25-2022 05:30
05-25-2022 05:30
Very disappointed, have earned 25,000 steps twice but not awarded.oldbutgold.
06-15-2022 17:26
06-15-2022 17:26
@Oldbutgold I'm glad you got it sorted!
Helen | Western Australia
06-02-2022 19:29
06-02-2022 19:29
Hi @Oldbutgold I'm a bit confused here. How do you know you did 25000 steps as the Flex 2 has no screen to tell you this? Is theflex 2 syncing to you phone OK otherwise?
But try restarting your Flex 2 a few times, and also update your app if there is an update available in the app store, and hopefully it won't happen again (though it is unlikely to restore anything lost)
06-07-2022 07:39
06-07-2022 07:39
06-15-2022 15:58
06-15-2022 15:58
So the problem is withfothe fitbit server, or the app. Not the tracker.
Does any basgesfshow up on https://www.fitbit.com/badges
Best Answer06-15-2022 17:26
06-15-2022 17:26
