10-03-2016
18:16
16:59
10-03-2016
18:16
16:59
10-04-2016 13:50
10-04-2016 13:50
@Harper34 Welcome to the Fitbit Community! I recommend checking that the time is correct on your time zone settings (account > advanced settings; on the Fitbit app). Then, perform a restart on your Flex. You should not experience that again.
To recover any lost steps; you can manually log an activity (check @GisselleM's post). You will be credited with accurate data for an specific activity.
Let me know how it goes! ![]()
Best Answer10-04-2016 16:45
10-04-2016 16:45
Best Answer10-04-2016 16:53
10-04-2016 16:53
Best Answer10-04-2016 16:55
10-04-2016 16:55
@Harper34 Thanks for your reply! To restart your Flex, do the following:
Now your tracker has been restarted and should work properly. Let me know how it goes! ![]()
Best Answer10-04-2016 16:58
10-04-2016 16:58
Best Answer10-05-2016 06:47 - edited 10-05-2016 06:48
@Harper34 I hope that helps!
I will be waiting for your reply, hopefully you'll be back on track by then!
Let me know how it went! ![]()
10-05-2016 12:19
10-06-2016 07:28
10-06-2016 07:28
@Harper34 I hope you're doing well! If it doesn't work; the best thing to do will be to report that to customer support as they can check further inside your tracker to see if there is something wrong with it. They will also check if a replacement is needed in your case!
Keep me posted. ![]()
Best Answer10-06-2016 16:31
10-06-2016 16:31
Best Answer10-19-2016 09:11
10-19-2016 09:11
@Harper34 I hope you're doing well! Were you able to resolve the problem with customer support? They are great!
In the meanwhile, check the new Flex 2, it is awesome. It includes a new design, new features, and you can even swim with it!
Give me any updates on this matter! ![]()
10-27-2016 08:07
10-27-2016 08:07
I did try the reset but so far no luck. I will try reinstalling next. Thanks for your help.
Best Answer11-01-2016 07:08
11-01-2016 07:08
@SaundraJo Welcome to the Fitbit Community! You can also try to set up your tracker as a replacement device (check @SteveH's post). Then use it again to see if it works properly.
Keep me posted! ![]()
Best Answer11-04-2016 05:37
11-04-2016 05:37
My flex is still not syncing. I spent two hours on chat with Aubrey. I upgraded phone (did not want to do that) and tried the paperclip trick. No luck.
Please help.
Thanks.
Amy
Best Answer11-06-2016 05:25
11-06-2016 05:25
@AmyJeanne Welcome to the Fitbit Community! Thanks for following the instructions given by customer support.
I recommend checking this syncing master post to get some syncing troubleshooting steps to fix this issue. Just search for the platform you are using within the post! If you already did some of the steps there, please do them once again.
Try that out and let me know how it goes! ![]()
10-05-2019 09:57
10-05-2019 09:57
Tracker batter charges but will not work when inserted into bracelet.
