11-21-2022 21:14
11-21-2022 21:14
Any help will be greatly appreciated.
Fitbit minutes on screen disappeared.
Was there until about an hour ago
Flex 2
Thanks!
Best Answer11-22-2022 04:40
11-22-2022 04:40
I finally figured it out. Can’t figure out how to remove the post.
Best Answer11-26-2022 03:48
11-26-2022 03:48
@krc314 Glad you figured it out. You can't remove the post but thecan edit the content if you want to to say problem solved or something similar
Helen | Western Australia
