07-27-2020
04:59
17:08
07-27-2020
04:59
17:08
Hoping someone can help... I’ve had my flex 2 for maybe 4 years and had no real trouble with it until the last week or so. My guess at the moment is that the battery can't hold any charge unless plugged into the charging cable. When I put the fit bit pebble in the charger, it lights up with one light and I can see the device detected on my iPhone app and it syncs and counts my steps. However as soon as I take it off the charger the light dies and tapping the device doesn’t light any of the leds. The app also can’t detect the device.
I’m wondering if I just have to get a new Fitbit or is this maybe something like a problem I faced with my iphones and ipods over the years, where the battery has gone beyond some sort of threshold? I had to fix those using 'trickle charging' which meant that I had to use a specific method to get the battery up to a level where it could start charging normally again. Has anyone else faced this issue? I’ve tried a reset with the button on the back of the charger as well as the method tapping the pebble itself but it hasn’t helped
08-02-2020 13:17
08-02-2020 13:17
Please clean the contacts on the charger and the flex 2 pebble with a damp papertowel or something.
Then charge the flex2 fully till all the dots are lighted up.
Then please restart your fitbit:
Then please try syncing.
please let me know if this was helpful or if you need additional guidance.
10-01-2020 22:04
10-01-2020 22:04
I have the same problem, but it does not want to reset at all
Best Answer10-02-2020 06:46
10-02-2020 06:46
There is something wrong with app. My died some time ego. Is 3 years old so I thought is gone. I've got newer one but took a chance for old and charged using new charger. Now I have 2 but can't connect them... Other fitbit devices become useless as well after recent updates.
Best Answer10-04-2020 01:30
10-04-2020 01:30
Hi, I have the same problem. While in charger it syncs up and shows 100% charged etc. but as soon as I put it back in band it dies and does not sync up. It becomes completely in active and does not count any activity. Please help.
