12-05-2019 00:41 - last edited on 08-20-2020 17:15 by MatthewFitbit
Hi,
My Flex 2 was flat and when I went to charge it, all the lights are flashing but it won’t charge. I have tried restarting (nothing happens) and re-adding it as a new device but the app just keeps saying “searching” and can’t find it.
Can you help?
12-05-2019 05:38
12-05-2019 05:38
I have the same problem with my flex 2 too.
12-09-2019 11:10
12-09-2019 11:10
Hi @daydream1 and @Shan_lovecc, welcome to the Community Forums! Sorry for the delayed reply.
Thanks for bringing this to my attention and for restarting your Flex 2 devices prior to posting. To better assist you guys with this, can you please let me know the pattern of the lights? Are all the lights white or there's another color? Please check: for more information about this. Please try the restart process several times and let me know how it goes.
I'll be around. Let me know if you have any additional questions.
12-11-2019 13:12
12-11-2019 13:12
Hi,
there are four white lights and one pink one, all flashing repeatedly (pulse kind of pattern). I have tried the restart process numerous times... all that happens is the lights stop flashing when I press the button then start again straight afterwards. Pressing the button three times creates no kind of response.
thank you
12-12-2019 05:18
12-12-2019 05:18
This started happening to my Flex 2 yesterday, exact same symptoms. Restart is ineffective.
12-16-2019 02:03
12-16-2019 02:03
I followed the steps to restart the device, however the light is keep fleshing(all 5 lights) and not respond.
My device bought two years ago.
12-17-2019 04:14
12-17-2019 04:14
I have the exact same issue. Started randomly one day when I woke up and it was just dead (not even the red light that means battery is empty). I put it in the charger and it started flashing all the lights at once. All white except one that is purple-ish. The lights are flashing very quickly, maybe about 3 flashes per second.
I left it charging, it never stopped flashing. It has been like that whenever I try to charge it for 3 days now. I have tried plugging it into a computer too, same thing happens. When I take it out of the charger it is all black, no reponse to anything.
I tried to remove the device from the app and deleted the bluetooth pairing, and now the phone cannot even find the pebble. Resetting it does not work, it just goes black when I press the button, and does not vibrate.
I am at a loss now.
12-17-2019 14:30
12-17-2019 14:30
Hi,
I started to have this issue today when I tried to charge. All four lights plus one purple one is constantly flashing. I've also restarted multiple times. Anyone find a solution yet?
12-18-2019 07:25
12-18-2019 07:25
No. It is already half a month, still not charging and light keep flesh.
I tried every way I know but still don't work.
12-20-2019 20:23
12-20-2019 20:23
I bought my mum a fitbit flex 2 in January 2018. And she sent me a video of it charging
all lights are flashing at the same time she said it has a pink color to it!
does it mean the battery is no good?
12-23-2019 15:43
12-23-2019 15:43
12-24-2019 05:39
12-24-2019 05:39
I just went through online chat and received a replacement or 50% off an upgrade. My flex 2 is over a year old. Worth a try and hope it helps
12-24-2019 11:12
12-24-2019 11:12
Thank you! She loves her fitbit
12-27-2019 09:13
12-27-2019 09:13
seeing as they discontinued the flex 2 earlier this year and that so many have this problem now I have to conclude that they did this on purpose. The flexes are not broken, just locked. I know mine had the software updated few days before this happened, and that must be when they added the code to lock it. And then the errorcode light pattern we get "doesn't exist", which is ridiculous - they definitely know what it means since they coded it in. So I have given up on my flex2 and fitbit as a whole. Will definitely not be buying another. I am really dissappointed that they would do this.
12-28-2019 14:59
12-28-2019 14:59
this is happening to mine as well. four 4 white and one pink flashing lights. reset didn't work.
12-28-2019 16:54
12-28-2019 16:54
12-28-2019 19:48
12-28-2019 19:48
thanks i thought that might be the case.
12-31-2019 07:52
12-31-2019 07:52
Hi, im having the same issue, have tried restarting several times but not getting anywhere, do you have any suggestions?
12-31-2019 12:32
12-31-2019 12:32
01-01-2020 04:13
01-01-2020 04:13
Yep, with mine this just happened as well, was still working and syncing a few hours ago. Bought just over 2 years.
Well, I've already been eyeing different brands so that's it for me, no more Fitbit for me.
