01-28-2021 23:33
01-28-2021 23:33
Hi there,
My flex 2 goes flat real quick. Unbelievably quick. There seems to be a lot
Of people with similar but different issues.
Can any suggest anything other than going to Garmin?
01-29-2021 12:49
01-29-2021 12:49
Hi, @Slotback, as I expect you know, all Lithium ion batteries such as in Fitbits (and Garmins!) have a limited number of recharges that they can accept before they begin to deteriorate. How quickly this happens partly depends on how well it has been looked after - the battery will deteriorate much more quickly if it is allowed often to discharge completely. Keeping your battery between 20-80% charged as much as possible will prolong its life. In addition, the smaller the battery, the shorter its expected life span.
Having said that, the Flex 2 is a much older device know, so significant deterioration in battery life is likely even if it was perfectly looked after. You could try giving it a restart - instructions here - as a restart will sometimes help as it will shut down any background activities causing unusual battery drain. You might also try cleaning the contacts - instructions - which also might help, but I think the most likely explanantion is that, sadly, your Fitbit friend may be coming towards the end of its useful life.
As I mentioned above, it is certain that this will affect any brand tracking device, or other battery operated device! Having tried a Garmin myself (though admittedly not verŷ recently) I found their app not nearly as user friendly as Fitbits, and syncing was a nightmare. That's why I switched to Fitbit.
If you would like to stay with Fitbit, I would suggest an upgrade to the Inspire series. The Inspire has a lot of improved features from the Flex (I like having the HR feature, personally) with almost as small a profile as the Flex and some lovely bracelets that make it look quite discrete. And, of course, it has a watch feature, so you don't need to where a second device. It can also be worn on the wrist or somewhere on your body and still count steps. I have to admit I love mine - but, of course, everyone's different.
I hope this helps!
01-29-2021 12:49
01-29-2021 12:49
I hope this helps!
01-29-2021 15:54
01-29-2021 15:54
