10-19-2021
06:38
12:50
10-19-2021
06:38
12:50
Hi All,
Had my flex 2 since C.2017 and suddenly seems to have broken over the weekend. Started out by randomly vibrating in 2-5 second bursts with the same sort of time between bursts, and now the battery has ran out it won't seem to charge. Occasionally I get the red light and a single faint white light but usually no response, have tried the resetting advice with the charger button etc but no luck. Nothing to suggest why it would have happened, not had a particularly hard knock or anything. I presume it's just done?
Thanks in advance if anyone has any advice!
01-22-2022 00:34
01-22-2022 00:34
Hi @GT9310 Yes I think you are right - it has died. The Flex 2 was a simple tracker (simple but wonderful - I loved mine). If restarts don't help there is nothing else you can try. Sorry (I understand you pain - mine died this week too 😒)
Helen | Western Australia
