02-23-2017
01:10
17:15
02-23-2017
01:10
17:15
Flex 2 light continuously flashing when charging. Even I try to restart by pressing the button which charging 3 times it does not restart or vibrate.
Checked for firmware update, and it shows there is no update to be done
Which light is flashing? Mine flashes white lights to let you know how the charging process is proceeding. It is a sort of a slow pulse rather than a quick flash. Is that what yoj mean?
Helen | Western Australia
Oh dear - that doesnt sound good! Just to make sure you have done the restart correctly, have a look at the proceedure below. If you are happy you have done it correctly Id suggest contacting customer service.
RESTART PROCEEDURE
Put your tracker into the charger so it has the charging lights showing. Then press the small buttin on the back of the charger 3 times within 5 seconds. It will vibrate with each press and then when all three are done it will very briefly flash all lights and then go back to charging lights and it is all done
Full instructions
http://help.fitbit.com/articles/en_US/Help_article/1186
I'd suggest you contact Customer Support as nothing has worked with the fixes you have tried.
http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Best AnswerGreat news @elsadoodle 👍
@PM_3 try restarting your tracker. Donit at least three times as one doesnt always work. Let us know how you go.
Mine is doing kinda the same. I suspect it is the charger and not the fitbit itself. Anyone have any tips for the battery charger?
Best Answer@DavidO82 Sorry no tips for the charger. It works or it doesnt.
Best AnswerMine is doing this too!! All lights flashing, one of which is pink. The unit won't work now.
@DianeB65 @Michelle1234567 try restarting the tracker several times. Let us know how you go.
Best AnswerYou will need to contact Support (link in my signature)
