06-15-2017
21:30
17:15
06-15-2017
21:30
17:15
My Fitbit flex 2 has been working well all day and now it is glowing orange/red with one white light and won't go away it isn't flashing it is solid and my battery is low.. I have no silent alarms set etc.. and I tried plugging in my Fitbit to charge it since the battery is low and it didn't vibrate or anything when I plugged it in and it is still glowing orange/red and white... Help please!
06-26-2017 07:04
06-26-2017 07:04
Wow, this is very strange my friend.
Are you still having this issue with the lights on your Flex 2? If so, I'd recommend leaving your tracker charging (even if it has medium battery level) around 1-2 hours, then try restarting your tracker 3 times in a row.
As you may know, the only color lights you should see on your Flex 2 are the following ones:
Give this a shot and let me know it goes!
Best Answer11-14-2017 04:00
11-14-2017 04:00
@MarreFitbit wrote:Wow, this is very strange my friend.
Best Answer01-12-2019 13:01
01-12-2019 13:01
This happened to me too!! I plugged it in and nothing happened. Around 14 hours later it was not fully charged
Best Answer01-13-2019 01:12
01-13-2019 01:12
Try restarting your flex 2 as @MarreFitbit suggested above.
Helen | Western Australia
