08-20-2020
17:01
17:07
08-20-2020
17:01
17:07
Went to a water park for a few hours came home and noticed that it was off. I thought the battery died so I plugged it to the charger. All lights lit up and than turned off. It did manage to sync my steps but since than it won't turn on. I tried to do the 3 button reset but nothing happens. Any ideas?
08-21-2020 00:12 - edited 08-21-2020 00:20
edit: my apologies. My first response was incorrect.
It does sound like water damage even though the Flex 2 should be ok at a water park. It's worth putting it in rice anyway and if that doesn't work then it would be worth contacting customer support to check your warranty options.
08-21-2020 07:25
08-21-2020 07:25
Apparently Flex 2 is not water proof.
Claire: It's only water-resistant and not water proof
