04-22-2022
05:18
12:08
04-22-2022
05:18
12:08
Today I woke up and let Fitbit know I was done sleeping. The stats showed my correct time in bed and the chart graphic showed awake and restless but the daily log shows 100% asleep ?? What’s happening?? As an example if I total the restless from the chart it’s 23 times and the daily log says 0.
04-27-2022
12:35
09:52
04-27-2022
12:35
09:52
Hi, @monibubbles , it sounds like you are starting and stopping sleep sessions manually in your app. The Flex 2 is designed to detect sleep automatically so you should not do this. I would recommend simply wearing it to bed and letting it do the work. You should find that your sleep results are accurate that way.
I hope this helps. Welcome to the forums!
