09-21-2017
05:58
16:59
09-21-2017
05:58
16:59
I have been given a Fitbit but have no idea which one it is how do I find out? Thanks
04-12-2019 21:56
04-12-2019 21:56
Do u know what north tracker fit bit is
06-09-2019 09:58
06-09-2019 09:58
mine doesn’t look like any of those
07-22-2019 21:39
07-22-2019 21:39
08-29-2019 08:04
08-29-2019 08:04
My app got wiped in error and I don't know which Fitbit model I have. Looking at the samples online doesn't help because although they are close they are not the same.
Question:
Do any of the Fitbit models need to be taken apart and then one of the 2 parts inserted into a USB socket for charging? Mine does. Do I have a Fitbit or some other manufacture?
Thanks
08-31-2019 17:40
08-31-2019 17:40
I don't know what mine is It doesn't show up on fitbit app
09-13-2019 09:11
09-13-2019 09:11
There is no camera on my typing box.
09-17-2019 11:41
09-17-2019 11:41
How do I find out which versa I have? I remember it was a special edition but don know if it is the versa lite, just versa, or versa 2
09-24-2019 12:55
09-24-2019 12:55
Could someone help me figure put what fit bit I have please
09-27-2019
04:17
12:12
JuanJoFitbit
09-27-2019
04:17
12:12
JuanJoFitbit
I can’t say specifically as I’ve just been given my friend’s old genuine Fitbit which has a charger that clips around the underside of the face (side to side) . The charger has the Fitbit symbol on it. I also have an exercise tracker, I bought from China, that I have to charge by pulling off the wristband and inserting into a usb charger . Sounds like yours is the non genuine one.
I did reply but it’s come up as a separate post. Hope my reply helped.
Moderator edit: merged reply
09-27-2019 19:11
09-27-2019 19:11
10-11-2019 12:32
10-11-2019 12:32
ive looked through all the fit bits online never found mine i think it is the force but i don't know
11-29-2019 10:02
11-29-2019 10:02
My Fitbits band broke idk which I have the bands just pull off and just push back on no clips or anything just opens at each end that inserts
11-30-2019 07:57
11-30-2019 07:57
The pics are not helpful because some models look the same. Isn't there a model number somewhere on the device?
11-30-2019 09:10
11-30-2019 09:10
11-30-2019 17:13
11-30-2019 17:13
Where can I go in Columbia, MO, for someone to help me figure out what model of Fitbit I have. I need a new wrist band.
12-09-2019 07:18
12-09-2019 07:18
I have a Fitbit that looks like the alta but when you slide off the band there is a usb connector to charge it. Which is this?
P.S. (Not sure if it is a fit bit I was told it’s a fit bit when I got it)
12-27-2019 02:26
12-27-2019 02:26
https://photos.app.goo.gl/XgaMEsQKA3j6irna9 what model is my fitbit my stepdad used it for a week like 2 years ago I just need to know what model so i can charge it thanks
12-31-2019 19:46
12-31-2019 19:46
Hi, none of the models seem to match the model I have. I cant say much about it other than it's purple, I doubt that would help though. It kind of looks like both the ace and alta.
01-03-2020 18:52
01-03-2020 18:52
I have the same problem but I still can’t figure out which Fitbit I have. Mine you can only take off half of the band and you can plug it into any charger cube to charge it
01-03-2020 18:54
01-03-2020 18:54
I have the same exact one and that’s what I’m trying to figure out
