02-24-2016
22:34
16:59
02-24-2016
22:34
16:59
02-25-2016 00:41
02-25-2016 00:41
Were these the instructions you followed?
http://help.fitbit.com/articles/en_US/Help_article/How-do-I-set-up-a-replacement-tracker/
If so, at which point did you get stuck?
12-28-2019 14:39
12-28-2019 14:39
Instructions doesn’t work I want to replace my old device with a new one, and do not loose my records
Best Answer12-29-2019 00:30
12-29-2019 00:30
@Johnelias what problem are you having?
Replacing a fitbit with a new one (of the same type) should be just a matter of going into the account section of the app using the same ID and password as you used for the original fitbit and selecting "set up a device". It will ask if you want to replace your original fitbit and will step you through the process. All your data, settings, badges etc will be retained.
Best Answer01-03-2020 21:54
01-03-2020 21:54
Go to your acct then add new device then pick which 1 you have and follow instructions it will work
