09-10-2015
16:41
16:59
09-10-2015
16:41
16:59
So a while back I lost my Flex charger. I bought one online and it didn't have a reset button. The charger worked a few times but now my Flex every time I plug it in flashes four of the five lights twice (two on either side of the middle one). My Flex did this when I first got it and I know this means it needs to reset, but obviously that's kind of hard without a reset button. I tired to connect a +5V to the middle pin and 0V to right pin, and then apply +5V momentarily to the left pin. It did not work. Is there any way I can reset it without a reset button?
Moderator edit: Updated title for clarity
09-10-2015 18:23
09-10-2015 18:23
Hi @CheyenneT
As you've noticed, the 3rd party chargers often don't have the hole in them to perform the reset. Fitbit does not support any other method of resetting the device and I personally do not know of any unsupported methods. Your best bet is to get an official fitbit charger, If you are in the US, they are available in the online store.
BJ | NC, USA
Flex and Charge | Windows 7 | Kindle Fire
09-10-2015 18:10
09-10-2015 18:10
There is no reset button for the flex. Here are the directions on restarting the flex:
1. Plug your charging cable into the USB port and insert your tracker into the charging cable.
2. Insert a paperclip into the small pinhole on the back of the charger.
3. Press on the pinhole for 3-4 seconds.
09-10-2015 18:23
09-10-2015 18:23
Hi @CheyenneT
BJ | NC, USA
09-15-2015 08:56
09-15-2015 08:56
Wow. I didn't realize third party chargers exist! Thanks for the input @peppergal!
11-14-2017 01:56
11-14-2017 01:56
Hi there, if you don't live in the US, you can't use the US cables as the voltage is different. My fitbit came without any ability to reset it, which is annoying. It is packaged, sent, and - effectively defective - all in legit fitbit packaging. Very annoying.
11-27-2017 16:22
11-27-2017 16:22
Hey, gang. Just figured out how to do a reset with a cheap-o after market charger. Simply pop the pebble in and out of the charger 3 times in 5 seconds. Voila! I'm back in action.
02-28-2018 05:28
02-28-2018 05:28
Just bought an after market charger, this trick worked! Thank you!!!
03-08-2018 10:58
03-08-2018 10:58
What is the "pebble"
03-08-2018 18:51
03-08-2018 18:51
03-24-2018 18:18
03-24-2018 18:18
It did not reset the time, any ideas?
04-23-2018 17:34
04-23-2018 17:34
You are a life-saver. I bought a cheap after-market charging cable when my original went out and it does not have the reset button. Your trick to rapidly pull it out of the charger 3 times won't like a charm. Saved me $ and a lot of heartache.
06-01-2018 19:54
06-01-2018 19:54
I tried this method and it didnt work. What could be wrong with
06-01-2018 20:00
06-01-2018 20:00
keep trying it took me 5 or 6 times to get the timing right
06-07-2018 22:12
06-07-2018 22:12
Worked for me! This SHOULD be the ACCEPTED SOLUTION, but I guess fitbit wants to sell everyone a new charger. I couldn't even find the link for their store!!!
06-24-2018 05:53
06-24-2018 05:53
Thank you soo much!! This worked!! Been trying for days!!
06-26-2018 10:53
06-26-2018 10:53
Hi every one! Thanks for sharing workarounds for this situation. Please take a look to our Warranty Policies before acquiring any non Fitbit product.
Keep in mind that our Limited Product Warranty does not apply to damage or defects caused by the use of non-Fitbit products.
Catch you later! 🙂
10-08-2018 21:36
10-08-2018 21:36
Hey
I having same trouble with my fitbit charge but i don't seem to find an official charger. Any idea where i might find these besides in the fitbit store ?
10-09-2018 01:26
10-09-2018 01:26
10-09-2018 07:29
10-09-2018 07:29
10-11-2018
07:57
10:28
10-11-2018
07:57
10:28
Hi there @JV2316 @SunsetRunner @LadyDi34715 Great to have you in the Fitbit Community Forums! 😄
Thanks a lot for the input @LadyDi34715 @SunsetRunner!
@JV2316, you can also purchase a new tracker from the Fitbit online Store. For more information on this, you can click here.
Any other thing you may need, I'm here to help!
