09-10-2015
16:41
16:59
09-10-2015
16:41
16:59
So a while back I lost my Flex charger. I bought one online and it didn't have a reset button. The charger worked a few times but now my Flex every time I plug it in flashes four of the five lights twice (two on either side of the middle one). My Flex did this when I first got it and I know this means it needs to reset, but obviously that's kind of hard without a reset button. I tired to connect a +5V to the middle pin and 0V to right pin, and then apply +5V momentarily to the left pin. It did not work. Is there any way I can reset it without a reset button?
Moderator edit: Updated title for clarity
11-12-2018 22:50
11-12-2018 22:50
Could u please go into a bit more detail about where to put the pebble please!! Thanks!!
11-12-2018 23:44
11-12-2018 23:44
11-13-2018 01:44
11-13-2018 01:44
Hi does this also work with the alta??
11-13-2018 04:27
11-13-2018 04:27
11-22-2018
04:30
09:42
11-22-2018
04:30
09:42
Hi there guys, good to see you in the Community Forums! 🙂
For anyone needing to restart their Flex and not knowing how exactly to, please, follow these instructions:
Plug the charging cable to any USB port or UL-certified USB wall charger and remove the pebble from the wristband and put it into the charging cable. Then, insert a paperclip into the small pinhole on the back of the charger for 3-4 seconds and then take the tracker out of the charger and put it into the wristband.
If you have any other tracker and you need to know how to restart it, follow the instructions on this link where you will find instructions for every tracker.
If you need to buy a new charger, check the Fitbit online store in the Accessories section.
Anything else, I'm here to help!
01-09-2019 04:04
01-09-2019 04:04
It worked!!! Awesome- thanks!
01-16-2019 03:03
01-16-2019 03:03
You're a lifesaver Thank you.
04-21-2019 11:12
04-21-2019 11:12
Omg thank youuuuuu!!!
04-28-2019 08:24
04-28-2019 08:24
You can also buy a replacement charger - with a reset hole - for about $2 on eBay. And they're not all 3rd party, many of them are also Fitbit brand products.
04-28-2019 12:54
04-28-2019 12:54
I buy 3rd party chargers because they're so much cheaper, and they last just as long. If you check on Amazon, you can find 3rd party ones that still have that little charging hole. I usually buy 2-3 at a time, so if I lose one or one stops working (eventually they all wear out), I'm not left high and dry.
I'm a huge fan of 3rd party bands, too, which come in a lot more colors and (for me) last just as long or longer, and you can get ones that stay on your wrist more securely.
05-07-2019 11:59
05-07-2019 11:59
Not all heroes wear capes. THANK YOU.
05-08-2019 09:17
05-08-2019 09:17
You're welcome ... as they say, necessity is the mother of invention!
05-08-2019 09:30 - edited 05-08-2019 09:31
The collection of bands I have is probably one of the main reasons I haven't upgraded my Fitbit. lol The only think I've noticed is the translucent plastic that the lights show through is usually black/clear on 3rd party bands and color-coordinated on Fitbit proprietary bands. I did manage to pick up a set of 3 proprietary bands on clearance at a Microcenter a few weeks ago for less than $5 so that was nice. There are advantages to using a time-tested product like this.
05-08-2019 11:18
05-08-2019 11:18
Ha! Me too! I have flowered bands, striped bands, pastel bands, earth tone bands, jewel tone bands...
06-07-2019 10:17
06-07-2019 10:17
Heya I just wanted to ask what is the pebble?
06-29-2019 23:03
06-29-2019 23:03
It's the black oblong thing that you pop out of the band and put in the charger. It's the actual tracker.
07-27-2019 16:08
07-27-2019 16:08
Why doesn't Fitbit just reduce the price of the charger a little bit?? 20 bucks for a little cable is really ridiculous and a big disservice to your customers who want to keep continue using your product.
07-28-2019 14:26
07-28-2019 14:26
Does it only work on flex 2 and not others like flex 1
08-20-2019 08:34
08-20-2019 08:34
Hi @SunsetRunner - would you please share the video? Thanks
08-22-2019 17:25
08-22-2019 17:25
I'm not using a 3rd party charger and still having this problem so...
