02-21-2017
05:58
17:15
02-21-2017
05:58
17:15
Have just added the Flex2 to my collection of Fitbits. Was so excited finally to have a tracker for my swim workouts. I find the time and distance swum to be 99.9% accurate. But calories burned is a farce. It estimates 1 cal per minute. I.e. 40 calories for a 40 minute swim. I'm 67, 140 lbs, 5'6" and very active. So what's going on? (I also own an Alta, charge HR and Charge 2).
10-12-2018 17:40
10-12-2018 17:40
10-12-2018 17:57
10-12-2018 17:57
My guess is that you are swimming in a 25yd pool. Change the pool settings to 50yd, and now you will get laps and calories correct. Then you can just figure ttl yards. Also, make sure your activity is listed as swim, not sport. .
10-12-2018 21:42
10-12-2018 21:42
10-12-2018 21:46
10-12-2018 21:46
10-13-2018 01:31
10-13-2018 01:31
10-13-2018 07:42
10-13-2018 07:42
It counted the laps and distance correctly. That's much more important to me than the estimate of calories. Hopefully they'll fix the calories. Sounds like a minor software glitch.
10-13-2018 10:09
10-13-2018 10:09
10-13-2018
10:12
10:09
HeydyF
10-13-2018
10:12
10:09
HeydyF
Same here. Mine was a gift bought off of Amazon.com. They have replaced two
of the "pebbles" with no change. I am using it for other exercise, but the
device is not good. As I wrote earlier, research is on for a device
that works. . . . .not from FitBit.
Moderator edit: Word choice
10-23-2018 10:19
10-23-2018 10:19
Hey guys! Let me give you a warm welcome to the Community!
Keep in mind to enter your correct demographics, height and weight, in order for you to get more accurate calorie results from swimming and all of your activities. You can also change the pool length for your Flex 2, on your Fitbit account, as one of the users mentioned, and then, please restart your Flex 2. As an additional troubleshooting, you can try to set up your tracker as a new device.
Wear it for a few days and let me know how it goes!
10-23-2018 15:20
10-23-2018 15:20
10-23-2018 21:52
10-23-2018 21:52
@scrane you are posting in a thread in the Flex 2 Forum. It might be better to post your query in Charge 3.
Helen | Western Australia
10-24-2018 06:02
10-24-2018 06:02
You will still get the same reply whichever thread you post on, all cut and past answers and mostly of very little help.
10-29-2018 04:27
10-29-2018 04:27
Hi everyone. Since the heart rate data isn't available while swimming (the Flex 2 doesn't have a heart rate monitor and the other devices disable this feature while swimming) the calories are more of an estimation based on the activity detected and the amount of movement recorded. Still if you feel the calories are incorrect you can manually log the activity and enter the amount you feel is more accurate.
Let me know how it goes!
12-05-2018 03:34
12-05-2018 03:34
I have a Charge 3 and bought it specifically for the swimming feature. This totally defeats the purpose of my purchase! I have called the Help desk multiple times and get the standard "set your pool length and restart."
Fitbit folks!!!!!!!!!!!! This has been a problem for a long time. I am not buying into the HR being disabled as the excuse for the calorie burn being grossly inaccurate. There are numerous online swimming calorie calculators that use weight, time swam, lengths swam and stroke to give you an estimate of calories burned. Guess what... Fitbit has all this information except for stroke. Come up with an average so you don't need the stroke type! Put the algorithm behind the scenes on the website and calculate something accurate to the Fitbit dashboard!! In the mean time, include the minutes in the active minutes total. With the right coder, I bet you could have this done in an afternoon!!!
The solution is EASY for Fitbit if they were truly interested in supporting the community!!
And yes....I'm pissed.
12-05-2018 04:48
12-05-2018 04:48
Pissed is an understatement.
I am right with you RRainman!
I still have the Flex2 and enjoy watching it screw up steps between swimming and the exercise log. It rarely gets it straight.
fitbit doesn't give a flip if the stuff works. It cracks me up when they try to get me to purchase another product.
I'm still looking at some of the other options out there . . . .
12-05-2018 04:54
12-05-2018 04:54
AND
repeat this worthless suggestion over and over and over again. It does not work. The Flex2 and it sounds like newer models are not any better. When is fitbit going to solve the problem? Perhaps losing customers will help?
12-05-2018 07:46
12-05-2018 07:46
This post makes sense. Fitbit people, please read. All you need to do is talk to your swimmer customers and come up with some simple software adjustments that allow swimmers to more accurately track their calories in a swim session. WE UNDERSTAND that tracking heart rate under water is never going to be accurate. But there are so many other ways that you can provide swimmers with a useful interface.
12-05-2018 08:01
12-05-2018 08:01
Dear Alvaro,
This response is not good enough. Have you read all of the comments? To suggest manual logging - quite frankly - is an insult to your customers, because, as your customers keep telling you, there are plenty of simple coding fixes which could address the problem. Why should we have to manually log data each time we swim? You don't need a fitbit to manually enter data. You can do that with a piece of paper and a pencil. You just need to provide a simple manual calorie "offset" adjustment for swim sessions. That way we only have to manually enter once, rather than every time we swim.
Please create a forum for swimmers so you can work with us to create a common sense fix. It will literally cost your company next to nothing. Otherwise you will lose all of your swimmers to the next fitness tracker brand which has a more intelligent swimming calculation system. And that will cost you a significant amount.
Thanks
12-05-2018 10:30
12-05-2018 10:30
Well said and I hope they dont delete your post as they keep doing with me. Challenging their moderators seems to be a crime in their eyes. I've never read a firum with so many complaints and poor excuses. The swim data has been an isdue for at least 2 years. Unfort for them I'm not shutting up and going away and I am in the process of trying to get a legal third party involved.
12-14-2018 07:19
12-14-2018 07:19
