02-21-2017
05:58
17:15
02-21-2017
05:58
17:15
Have just added the Flex2 to my collection of Fitbits. Was so excited finally to have a tracker for my swim workouts. I find the time and distance swum to be 99.9% accurate. But calories burned is a farce. It estimates 1 cal per minute. I.e. 40 calories for a 40 minute swim. I'm 67, 140 lbs, 5'6" and very active. So what's going on? (I also own an Alta, charge HR and Charge 2).
01-14-2019
07:25
06:27
01-14-2019
07:25
06:27
Thank you for your feedback everyone. If you have concrete ideas to improve this please do share them on the Feature suggestions board. Search for the idea first to see if one already exist so you can add your vote. The more votes an idea gets the more likely the developers will try to implement it. Not sure how simply this may be but I do know the team is constantly working on improving the feature as newer trackers do have this too so it will benefit existing and new Fitbit users.
I'll be around!
01-14-2019 08:12
01-14-2019 08:12
Why is this down to Fitbit customers to come up with a solution to incorrect calories burnt/inaccurate swim data plus the many ither problems Fitbit seem unable to resolve? Isn't it about time Fitbit took responsibility for their failings and come up with some answers themselves??
01-14-2019 08:47
01-14-2019 08:47
01-23-2019
07:08
06:27
01-23-2019
07:08
06:27
Hey guys, @JustinSG and @Everuby. I hope you are doin' fine!
Thanks for your feedback in regards of this inconvenience that you are experiencing with the calories burned after you complete you swim session. Please note that our team always keeps an eye on the forums and pay too much attention on those areas that need special attention so they can improve our products and services.
I will appreciate your patience and understanding!
08-14-2020 10:00
08-14-2020 10:00
HI moderator
I have my fitbit ionic set to autorecognize - it then asks you to choose laps - laps mess it up as I swim alternate strokes each length not 2 at a time and fitbit doesn't recognise it - I then have the correct length of pool set and to record lengths - start it in swim mode when I begin swimming - I swim 40 - 45 lengths at 1 min average per length medium fast - fitbit states I have only burnt 230 ish calories - thats half of what it should say - read the following -
The average person burns 430-575 calories per hour swimming leisurely.
The number of calories you burn swimming will depend on your weight and the distance and speed you swim. A 150-pound (68kg) person swimming recreational backstroke will burn 344 calories per hour. A 200-pound (90.8kg) person swimming freestyle laps with vigorous effort will burn 935 calories per hour.
I should burn about 500 calories per swim
Calories burned per minute = (MET x body weight in Kg x 3.5) ÷ 200 there is a list of MET scores online
What calculator is fitbit using ?
08-14-2020 10:11
08-14-2020 10:11
08-14-2020 11:50
08-14-2020 11:50
08-14-2020
12:17
12:45
LizzyFitbit
08-14-2020
12:17
12:45
LizzyFitbit
HI thanks I will try that but seems weird
09-09-2021 06:27
09-09-2021 06:27
Hi I have the new Luxe - similar issue. Distance is measuring ok but calories are sooo far it’s ridiculous! I’ll be contacting them to get this addressed hopefully
02-09-2022 15:40
02-09-2022 15:40
I have a similar issue. I swim regularly and have my set my Fitbit correctly and it still gives me 3 calories per minute. I’m no Michael Phelps but I know I’m burning more than 141 calories for 1200 yards. Irritating.
02-10-2022 01:59
02-10-2022 01:59
I wrote and called fit bit several times and got no where they don't seem to care so switched to a garmin then an iwatch - both good but iwatch easier for me to see
02-10-2022 07:22
02-10-2022 07:22
06-02-2022 07:14
06-02-2022 07:14
Same issue with charge 5, I'm just using it as a timer at this point.
