01-21-2017
		14:03
		17:15
		01-21-2017
		14:03
		17:15
Hello,
For the past couple of days my Flex 2 has removed steps. I reach 10,000 steps, get the buzz and little celebration etc and next time I sync I am down sometimes up to 3,000 steps. Has this happened to anyone else?
11-13-2018 05:50
 Community Moderator Alumni are previous members of the Moderation Team, which ensures conversations are friendly, factual, and on-topic. Moderators are here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              11-13-2018 05:50
Hey everyone! I hope you are doin' great!
If you seem to be losing steps after you sync your Flex 2, in order to avoid this from happening again, I'd like you to try the following:
- If you have more than one Fitbit device, don't try to sync both at the same time. Please put one of them maybe in a different room or as far as you can.
- Reboot the Bluetooth on your phone
- Reboot your phone
- Sync your Fitbit devices
Let me know if that helps!
11-13-2018 06:09
11-13-2018 06:09
 Best Answer11-19-2018 10:02
                              11-19-2018 10:02
Hey @MayzSa, thanks for the update!
I appreciate you have taken the time to try the troubleshooting that I posted above. Since the issue persisted, sounds good that you have return it and get a new one. 🙂 If you have questions or comments in regards of the usage of your replacement, keep me posted!
I'll be around!
11-20-2018 05:38
11-20-2018 05:38
I am also a bit wary of the battery life on my Flex 2. How long would you say your Flex is lasting?
 Best Answer11-20-2018 05:48
11-20-2018 05:48
 Best Answer11-20-2018 06:43
                              11-20-2018 06:43
Hey @pieatot, I hope you are doin' fine! The battery of your Flex 2 can last up to 5 days with normal use. However, if you see that it is not lasting as expected, I'd like you to take a look at the tips in this help article: Can I improve my Fitbit device's battery life?
Thanks for the input @MayzSa!
Let me know if you have further questions guys!
11-23-2018 08:26
11-23-2018 08:26
My Flex 2 seems to last at least 4 days but i don't actually use it everyday. And as a Flex 2 user i have gotten used to the occasional lost steps/0 active minutes issue. I ran for about 20 minutes yesterday and when i recorded it the details were : 22 mins and 174 calories with my overall step count around 12k. When i synced it again today the details have now become 22 mins with 24 calories and overall step count of 4k. I'm really getting tired of having to separate my trackers when i sync. It shouldn't be like this. I would exchange it for a new flex 2 but i think this issue is the same for all flex 2 trackers once you mix it with other fitbit models.
 Best Answer11-23-2018 08:30
11-23-2018 08:30
Thanks for the tips Heydy. I will try those tips and see if it there is improvement. unfortunately battery life is not the biggest issue with the Flex 2
 Best Answer11-24-2018 07:20
                              01-07-2020 11:45
01-07-2020 11:45
Lost a whole treadmill run. Picked it up one day, and disappeared the next day.
 Best Answer01-11-2020 06:29
01-11-2020 06:29
Hey aisha_kat,
I used to go through the same thing with my Flex 2. I took many suggestions but it still kept happening. Once I upgraded to the Versa the same thing was happening until I found it easier to initiate the workouts straight from the device instead of using my phone or just trusting that it would automatically pick up my movements and register a workout for me. Since I've upgraded and started the workouts from the device, I've had no more issues. It now works great.
 Best Answer01-23-2020 03:30
01-23-2020 03:30
 Best Answer03-19-2020 13:50
03-19-2020 13:50
I only have only one Fitbit Flex 2 And all day have been syncing and it rolls back to 4800 steps. I deleted the app from the phone I reset the flex and it is still doing that. Any thoughts?
 Best Answer03-19-2020 18:25
03-19-2020 18:25
 Best Answer03-20-2020 04:28
03-20-2020 04:28
 Best Answer03-20-2020 08:06
03-20-2020 08:06
The issue I’m having is that after I sync, it puts the days steps on the previous day and starts me back at zero. Like I got 10,000 yesterday (Thursday), but when I synced it got loaded up for Wednesday and Thursday restarted...leaving me with a 300 step day as it was already night. Help?
 Best Answer03-20-2020 08:13
03-20-2020 08:13
Uninstall the one in your laptop and try using your phone exclusively. This seems to confuse the Flex 2 also.
Make sure the fitbit app on your phone is updated(latest firmware).
Reset the phone and the tracker again.
That's all i can think of. Hope other more experienced users chime in here.
 Best Answer03-20-2020 08:15
03-20-2020 08:15
How many trackers are you using? Just the flex 2?
 Best Answer03-20-2020 09:06
03-20-2020 09:06
 Best Answer03-20-2020 09:09
03-20-2020 09:09
