11-10-2020
14:27
04:20
11-10-2020
14:27
04:20
All 5 lights flashing when in charger but does nothing when not in charger. No response when tapped. Have tried the steps to resetting (paper clip in hole for 4 seconds) a couple times and no result. Thanks!
11-10-2020 15:24
11-10-2020 15:24
Hi @BettyB79 the Flex original, which it seems you have, is quite a few years retired. It could be that it's just reach the end of life. Before mine died, I had to restart it a few times each time I recharged it. Is it still able to sync the data to the app and server?
11-10-2020 22:09
11-10-2020 22:09
Hi, no it’s not doing any syncing I’m afraid. Guessing it may have died 😭
11-11-2020 02:57
11-11-2020 02:57
My Flex has also stopped syncing. Wonder if something has changed in the app?
11-11-2020 16:58
11-11-2020 16:58
Mine has stopped syncing as well
12-22-2020 17:22
12-22-2020 17:22
I'm just ticked. It's the type of device that's simple and compact. I wear the piece in my sock (or bra), that's right I don't use the rubber bracelet. All I'm interested in is tracking my steps and counting calories, you know the KISS principle. The newer stuff is too convoluted and glitzy and darn it now this little gadget is becoming obsolete. Why can't fit bit keep making it HELLO!!!
12-22-2020 21:52
12-22-2020 21:52
@susieserb the Inspire 2 has the optional clip, so you might just like it.
12-23-2020 07:01
12-23-2020 07:01
Awe TY..I wear nice jewelry (like all the time 😊) and don't want this type of stuff to show. So to clip means an added element to contend with. The Flex has that awesome little chip that can slide into my undergarments or socks. I just keep buying them off of eBay till IDK...sigh.
12-23-2020 07:26
12-23-2020 07:26
@susieserb you don't have to use the clip. With the Inspire 2, it has the pebble piece, like your Flex. The clip is for those wanting to put it on their wasit band, pocket or bra.
12-23-2020 07:35
12-23-2020 07:35
Really!! Going to search for a pic!!
AND again TY!!!
