11-24-2019
16:29
16:59
11-24-2019
16:29
16:59
Long story short I disabled my tracker from my account, because I was having a lot of trouble with it syncing. I've been trying reconnect the tracker to my account, and it doesn't want to connect to any of the devices that I have the app on(iPhone XR, Android tablet, Windows Computer), it's stuck on "Searching, and Not Working". I've tried everything from restarting the device, turning the Bluetooth off and on, doing a fresh reboot restart with the charger and paperclip. I spoke to someone from Fitbit, and we came to the conclusion there is a glitch in the app. When are we going to get a fix for this, my fitbit is more or less useless, because of this.
11-24-2019 21:04
11-29-2019 16:00
11-29-2019 16:00
I am having the same problem with my fitbit. I HAD it connected and then lost the fitbit so I took it off my account. I later found it (lucky me!) but am not able to get it to upload again. My tracker is "found" but I can't get past the next step (it vibrates but nothing else happens).
12-02-2019 04:14
12-02-2019 04:14
Same here. I have tried everything, but my Flex wont sync. I feel like they are trying to force us to upgrade.
12-04-2019 19:47 - edited 12-04-2019 19:49
I think I'm in the same boat ----- Hope this makes you feel better about your issue. I'm hopeful someone will provide us with some guidance and a workable solution. No suggestions to upgrade or buy another tracker wanted or needed.
12-05-2019 13:02
12-05-2019 13:02
I had to uninstall and reinstall. I thought all my history would be lost, but it wasn't. Works great now. Good luck everyone with this issue. Frustrating!!!
12-05-2019 17:21
12-05-2019 17:21
01-31-2020 10:31
01-31-2020 10:31
If your tracker is not communicating with your phone to sync, why would you think it will communicate with the phone slurring a setup.
First step is to remove the tracker from your phones bluetooth, you have removed it from your Fitbit account.
We now want to remove the tracker from every other devices Bluetooth if the device is nearby, many have said they tried several phones.
Let's check for phone updates, Fitbit app updates, shut phone off and restart tracker.
Now try the setup again.
If you still have issues. Please include the phone model.
01-31-2020 11:21
01-31-2020 11:21
01-31-2020 11:27
01-31-2020 11:27
Sorry my comment was not directed to any individual @Liz022070
I was simply saying what the first steps in trobleshooting would be. Since not many actually posted what they tried.
02-05-2020 20:10
02-05-2020 20:10
I can’t seem to connect my Flex to my iPhone 6. Tried everything above:
- reboot phone
- reboot Flex
- turn off Bluetooth
- still nothing
- use dongle on laptop
And it does show lights and holds charge.
02-08-2020 15:18
02-08-2020 15:18
My app told me to update, so I did, this was back in mid-December and ever since I have had the same issue as the rest of you are having. I too have tried everything suggested by Fitbit. I even bought a new "used" fitbit of the same model and it would work for a day or two and then not. So now I have two of them, and neither tracker records/saves my steps. So frustrating. What is next, changing companies? Is there a date for a fix with the app? (Below it says they spoke to representative who said glitch in app).
