09-29-2016
21:28
17:15
09-29-2016
21:28
17:15
Does the Flex 2 track steps on a stationary bike? I have painful plantar facitis and have been using a stationary bike instead of a treadmill to relieve stress on my foot. The zip only picks up steps if I attach it to my shoe. Since the Flex 2 is an activity tracker will I be able to wear the wrist band and have the activity counted?
10-01-2016 08:27
10-01-2016 08:27
I'm no expert on this, but my guess is that it probably would not track activity on the bike, because the accelerarometer tracks arm movement and unless on one of those bikes that has moving handlebars, I can't see it happening.
I'm perfectly willing to admit that I could be wrong, though. ![]()
Best Answer10-01-2016 10:01 - edited 10-01-2016 10:02
It's nice to see you around the Community @sjhop, hope you're doing great!
I agree with @PDADoc, Flex 2 only automatically tracks outdoor bike, because it needs to detect forward motion.
The best thing to do for stationery bike is to log it manually. In order to do so, do the following:
Fitbit.com Dashboard
Fitbit App for iOS
If your iOS mobile device supports 3D Touch, you can also log an activity from the home screen with the Quick Action menu accessed by 3D Touch.
Hope that helps!
10-02-2016 08:41
10-02-2016 08:41
Thank you for responding.
Best Answer11-01-2016 06:39
11-01-2016 06:39
FitBit Flex2 definetly works when you're outdoors mountain biking. It logs as it's supposed to. However, I do Spin classes, and found to my dismay that it did not record my progress. My guess is that it didn't log because the bikes are stationary. I had to manually enter my bike ride as a custom activity.
Best Answer11-29-2016 13:30
11-29-2016 13:30
If my tracker is in just the right spot, at the top of my ankle, it *may* capture my pedal rotations. I would have assumed it would also capture the forward motion of my foot, which would be just as good an indicator of actual movement (if not better) than a wrist swing. I do a lot of stationary biking while watching t.v., I am disappointed that the activity isn't tracked. Not really interested in entering it manually, as it defeats the purpose of real-time activity feedback. Will you please suggest a firmware update that will capture this movement more precisely? Thank you!
11-29-2016 21:53
11-29-2016 21:53
11-30-2016 06:36
11-30-2016 06:36
Flex 2 will not auto recognise spinning in my experience because it will not detect the movement correctly. An elliptical trainer uses arm movements so that can be detected.
Three options I think
1... Manually track as suggested. Which I agree defeats the object somewhat.
2... The Surge has an option to log Spinning and that works really well for me.
3... Remove the pebble thing from the band and put it in your sock... not sure what it would count but as your leg is moving that would probably be worth the experiment.
11-30-2016 07:48
11-30-2016 07:48
11-30-2016 07:51
11-30-2016 07:51
Sorry... the Fitbit Surge... another Fitbit device more like a smart watch than a band. I own both. I use the Flex 2 for swimming, everything else I use the Surge because it has heart rate monitoring and GPS.
Best Answer11-30-2016 09:07
11-30-2016 09:07
Best Answer12-02-2016 08:34
12-02-2016 08:34
I have been putting the band on the bottom of my shorts with a safty pin thru one of the holes. It is an up and down motion instead of a forward motion but it seems to be picking it up..I'm disapointed in the fact that it does not convert my mile that I swim as steps like my LifeTrac did. Entered manually it counts it as active time but 0 steps and that sucks!
Fit bit, if Lifetrac can do it, then you guys should be able to figure it out!
12-02-2016 09:56
12-02-2016 09:56
Best Answer12-04-2016 06:10
12-04-2016 06:10
Yes I guess they could figure it out but it isnt steps so shouldnt be counted a steps! Personally I like the calorie amount as an overall way to track the activity you have done rather than converting to a (fictitious) amount of steps in a non step activity.
Helen | Western Australia
Best Answer12-13-2016 12:13
12-13-2016 12:13
I hook my Flex 2 band through my shoestring when I am on a recumbent bike. It adds one step for a full pedal rotation of just one foot. When you walk, it's adding steps for each time you place either foot on the ground, not so when biking.
12-31-2016 09:58 - edited 12-31-2016 10:01
Put my Flex on the top of my foot in my sock... Kind of recgonized it cause it gave milage as 5 miles and went in and said it was bike and it all popped up with the miles and that i did it for 30 min. Getting one of those magnet holders to put on shoe lace and see what happens then.
Bike at Saturday, December 31, 2016, at 10:23AM 5.00 miles 30:00 min 151 cals
12-31-2016 12:13
12-31-2016 12:13
Charlypp-- I finally found an after market clip for my Flex 2 to use on my waistband so that I can wear it like I did the Zip or FitBit One. I had been putting the FitBit One on my shoe while on my bike and that seemed to work. Wish that FitBit would design a waistband clip for the Flex 2. Have a healthy and happy New Year.
Best Answer04-06-2017 08:26
04-06-2017 08:26
I tried the third option and that is how I lost my first fitbit. 😞
Best Answer04-07-2017 06:17
04-07-2017 06:17
It is not a fictishes number of steeps! If you've ever been on a recombinant bike you would know that it is exercising just like walking , if not more because you can increase the tension.
Best Answer04-07-2017 06:48
04-07-2017 06:48
The number of steps is ficticious - you are not taking steps on a bike. The exercise isnt ficticious though, I certainly agree there!
