10-06-2016
14:11
16:59
10-06-2016
14:11
16:59
10-07-2016 07:13
10-07-2016 07:13
Welcome to the Community @SunsetRunner. Thanks for troubleshooting this inconvenience by yourself. First, if your tracker is not resetting at midnight, I recommend checking your timezone by doing the following from your iOS Fitbit app:
1. Tap account
2. Tap Advanced Settings
3. Checked your timezone
Also, I recommend restarting your Flex one more time and doing a force sync by following these steps:
1. Open the Fitbit app from your iOS device. Sign into your account if you haven't done so already.
2. Tap your tracker name at the top of the app dashboard.
3. Make sure your tracker has battery life and bring it near to your iOS device.
4. Scroll down and tap the "Sync Now" tile and wait for the sync to complete.
I hope this helps, let me know the outcome. ![]()
Best Answer10-08-2016 00:37
10-08-2016 00:37
Best Answer10-08-2016 22:41
10-08-2016 22:41
I also want to add that my friend which is living in the same neighborhood also having exact same problem with her flex.
11:57
09:01
10-11-2016
11:57
09:01
@SunsetRunner I hope you're doing well! That is very strange! Usually, that kind of trouble gets fixed when adjusting the time zone all over again. Now, as you are using the Fitbit app for iOS devices, we are going to try something different to fix this, please follow:
This should work, but if for some reason it doesn't, these tips about travelling with your Fitbit tracker should also help.
Let me know how it goes! ![]()
Best Answer08-04-2019 17:03
08-04-2019 17:03
I have tried everything to fix my timezone but nothing works. I have deleted the app, turned the timezone automatically detect off and on, nothing works
08-06-2019 13:13
08-06-2019 13:13
Hi
Have you managed to resolve your problem? I'm experiencing exactly the same thing and not sure what to do about it? Any advise would be greatfully recieved.
Nic
Best Answer08-07-2019 16:18
08-07-2019 16:18
I was able to fix it. I had a previous apple watch that was paired and when I deleted it and did a reset, my timezone worked
Best Answer08-12-2019 04:37
08-12-2019 04:37
Best Answer10-22-2019 10:01
10-22-2019 10:01
My issue is not traveling or time zone. I had to recharge my Fitbit after it died at work. The time never changed to the correct time again even after supposedly syncing!? I am very disappointed in the Versa. So now my alarms go off at incorrect hours and times too.
Best Answer02-29-2020 13:52
02-29-2020 13:52
This solution did not work. I decided to try deleting and repairing the Ionic with the App and that worked. Either there is a bug in the App or the Ionic that hangs the sync on restart when the battery in the Ionic becomes fully discharged.
Best Answer03-11-2020 05:56
03-11-2020 05:56
How did you repair the ionic. I couldn't find the feature in the app.
And there is certainly A **ahem**ty BUG when your device dies out of battery and it can never show correct date and time again... How wonderful !
I had to factory reset the device to fix the time which was again a **ahem**ty process.
