07-28-2015
19:37
16:59
07-28-2015
19:37
16:59
I have been using my flex for months now but noticed recently that it's not showing the mapped routes I walk. How do I get this back?
07-29-2015 02:25
07-29-2015 02:25
Hi Edson, thanks for the tips. Unfortunately none of them worked.
The routes show on my computer under "recent activity" but not on my phone. No idea what to do next! Somebody out there might have the answer. 🙂
07-29-2015 13:32
07-29-2015 13:32
@Jeffna Thanks for the update. I would like to confirm you are looking for your maps by following this path:
Go to your Dashboard, select "Track exercise", scroll down to locate your recent activity which should show the map and tap on it.
If your mobile device still doesn't show your maps, please provide me with the following information to further investigate:
- What type/model of mobile device are you using?
- What software version is it running?
- Were your maps showing previously?
Looking forward to your new comments.
07-28-2015 20:53
07-28-2015 20:53
It's great to see that you've visited the Fitbit Community @Jeffna. I haven't heard about any issues with the route graphs. I would recommend rebooting your phone. If this doesn't work please log out from the app and log back in. As a last resort, try uninstalling and reinstalling the app. This should settle everything up. Let me know how it goes.
Thanks for stopping by, see you around.
07-29-2015 02:25
07-29-2015 02:25
07-29-2015 13:32
07-29-2015 13:32
07-29-2015 18:43
07-29-2015 18:43
Woo Hoo! I have my maps back! Thanks Edson! You're a genius 😄
07-29-2015 19:37
07-29-2015 19:37
@Jeffna Thanks for the update and for your kind words. I'm glad to hear that you are back on track.
Hope to see you around more often.
07-29-2015 20:43
07-29-2015 20:43
Thanks 🙂 Just smashed a 8km walk! Did my planking now for a shower. Take care and thaks once again.
08-04-2015
13:52
15:01
JuanJoFitbit
08-04-2015
13:52
15:01
JuanJoFitbit
I went to Track Exercise and the walk I just tracked is not there. I have a Motorola Droid Turbo and it worked yesterday - I can see yesterday's map but not today's.
It's running Android 5.1
Moderator edit: merged reply
08-04-2015 14:26 - edited 08-05-2015 13:03
Thanks for taking a break from stepping to visit the Community @rebel3217. Please make sure that your recorded activities are lasting at least 5 minutes in order to show up on your Dashboard. If so, please confirm that you have followed the above workarounds to resolve the issue.
Catch you later.
08-04-2015 14:29
08-04-2015 14:29
@Edson wrote:Thanks for taking a break from stepping to visit the Community @rebel3217. Please make sure that your recorded activities are lasting at least 5 minutes in order to show up on your Dashboard. If so, please confirm that you have followed the above workarounds to see resolve the issue.
Catch you later.
I am walking for more than 5 minutes. I did the same route twice today that I did yesterday and it worked yesterday but not today. I even tried uninstalling and reinstalling the app but it didn't help.
08-05-2015 05:42
08-05-2015 05:42
Did a restart on the tracker and now everythings seems good. (so far!)
08-05-2015 13:06
08-05-2015 13:06
@rebel3217 Thanks for letting me know how you have fixed the issue. Hopefully everything works fine from now on.
Nice work! Now, let's get back to stepping.
08-13-2015 13:20
08-13-2015 13:20
I kept having this problem and tried everything I could think of - restarting the tracker, uninstalling and reinstalling app, turning Bluetooth off and back on. The only thing that seemed to help was rebooting my phone every time I wanted to track a walk. Then I noticed if I cleared Fitbit from my Recent Screens on my phone it would work. I also turned off Wi-Fi and set Location to Device Only and the GPS map was more accurate. You could give that a shot and hopefully it will help.
08-13-2015 14:32
08-13-2015 14:32
@rebel3217 At this point, it would be a good idea contacting Customer Support. They will be happy to check out your case and provide further assistance as soon as possible. Thank you for your patience while dealing with this situation.
Catch you later.
02-22-2017 13:52
02-22-2017 13:52
I am newish to the charge 2. Here's my question, I had to replace my droid turbo 2 with a new one and now it is not showing a map tracking where I went. Everything else is working great though. And where is "track exercise" on the dashboard? I can't find it anywhere....
03-10-2017 06:08
03-10-2017 06:08
Hi Hope you can help, I have the same issue... my app doesn't show my route nor does the online dashboard. I know that it has tracked it as my "Recent Activity" has the Location symbol on the run.
My model: Fit bit charge 2
Software: Samsung Android
Maps: Yes there were showing previously.
( Please note I carried my phone with me on the run so it should be able to track the location)
04-05-2017 15:59
04-05-2017 15:59
I am having the same problem also. My maps used to show on my phone. Now they don't.
05-07-2017 13:50
05-07-2017 13:50
Since 5th May my maps stopped showing on Android app. Just red circle whirls. No maps load. PC/web is fine. Maps are there but not on app. App just stuck trying to load all of my maps and none loading ???
05-08-2017 04:29
05-08-2017 04:29
@Angieb553 wrote:I am newish to the charge 2. Here's my question, I had to replace my droid turbo 2 with a new one and now it is not showing a map tracking where I went. Everything else is working great though. And where is "track exercise" on the dashboard? I can't find it anywhere....
If you tap the exercise tile and then the little stopwatch icon on the top you can track exercise with the phone app. Just hit the red arrow. When you're done tap Pause then hold down Finish.
07-11-2017 14:44
07-11-2017 14:44
I am suffering the same problem. The map shows on the initial tracking but once closed it no longer appears. It used to. Hope you can throw some lightbon a fix
