02-17-2021 23:20
02-17-2021 23:20
I have a fitbit flex which I've not used for ages, so wanted to check if it works before I order a band for it.
It charges. I was able to pair it to my phone but can't remember if the taps etc. should work outside of the band or not. currently it doesn't show any light if its outside of the charger.
It doesn't sync outside of the charger. Does it need to be in a band before I can verify any of this? Can I simulate it being in the band?
02-18-2021 09:01
02-18-2021 09:01
Hi @apurvashukla quite a few people would just tuck the Flex pebble into their pocket or down their sock in order to count the steps, so you should be able to check to see if it's registering your steps. In case you need it, click to see the Flex user manual and related articles. Let us know what happens.
Best Answer02-18-2021 09:34
02-18-2021 09:34
Best Answer02-18-2021 09:38
02-18-2021 09:38
I had a Flex and you can still use it when it's not in the band. You try a restart of the Flex?
Best Answer02-18-2021 09:44
02-18-2021 09:44
Restart directions - This only works with authentic Fitbit charger
Plug your charging cable into a USB port on your computer or any UL-certified USB wall charger
Remove the pebble from the band and insert it into the charging cable
Insert a paperclip into the small pinhole on the back of the charger
Press on the pinhole for 3-4 seconds
Take your tracker out of the charger and insert it back into the band.
