05-19-2015
01:51
16:59
05-19-2015
01:51
16:59
I cannot find the gear button on the dashboard for my Fitbit. It is supposed to be in the top right- hand corner. The only icon I can see there is the'+' icon. I want the find 'settings' for my dashboard. Would appreciate some help
Moderator edit: Updated title for clarity
05-19-2015 02:08
05-19-2015 02:08
Are you looking on the web dashboard or an an app?
On the web it's here:
You can also go directly to the settings via: https://www.fitbit.com/user/profile/edit
05-22-2015 13:56
05-22-2015 13:56
It's nice to see you here in the Community @WEEMAC @SteveH! Great steps @SteveH, loved them.
It seems that you're seeing your dashboard on your mobile phone and that's why you're getting the "+" instead of the gear icon. The gear looks like the one that our friend @SteveH shared with you on the screen shot. The gear is only available when taking a look at your dashboard by using a regular computer. ![]()
10-07-2018 08:11
10-07-2018 08:11
What website
@SteveH wrote:Are you looking on the web dashboard or an an app?
What website
Best Answer10-07-2018 08:22
10-07-2018 08:22
That's at www.fitbit.com (when you are logged in to your account)
09:15
10:23
10-11-2018
09:15
10:23
Welcome to the Forums @Airgun! 🙂
As @SteveH mentioned, if you pull up your dashboard on your computer by going to fitbit.com, you will see the gear icon to access your settings from there at the top right corner.
If you're on the Fitbit app, by tapping on the icon at the top right corner, you will be able to access your account information where you can also access your settings.
Let us know if you have more questions!
11-30-2018 03:35
11-30-2018 03:35
I can't find either setting or the gear icon on my charge3 screen? Can anyone help?
Best Answer11-30-2018 03:35
11-30-2018 03:35
I can't either!
Best Answer11-30-2018 03:40
11-30-2018 03:40
@giggling the posts in this thread are about the web dashboard at fitbit.com not the tracker itself. What setting are you looking for?
Best Answer11-30-2018 04:19
11-30-2018 04:19
It's fine thanks. Found it now.
Best Answer03-22-2019 10:10
03-22-2019 10:10
If you click the icon of your device to the left of battery and accounts icons in upper right corner, it will take you to settings for silent alarms and other settings I suspect this is equivalent to the gear icon. Hope this helps.
03-22-2019 10:40
03-22-2019 10:40
If you click the icon of your device to the left of battery and accounts icons in upper right corner, it will take you to settings for silent alarms and other settings. I suspect this is equivalent to the gear
@WEEMAC wrote:I cannot find the gear button on the dashboard for my Fitbit. It is supposed to be in the top right- hand corner. The only icon I can see there is the'+' icon. I want the find 'settings' for my dashboard. Would appreciate some help
icon. Hope this helps. I know this is a reply to a really old post, but I was looking for this information today and couldn't find an answer.
Best Answer03-22-2019 15:26
03-22-2019 15:26
Best Answer06-28-2019 13:51
06-28-2019 13:51
where is gear icon on the dashboard
Best Answer06-28-2019 13:54
06-28-2019 13:54
I don't have the gear icon either. It's in the bottom right hand side and looks like a telly.
Best Answer10-06-2019 10:23
10-06-2019 10:23
There is no gear icon i could find but to change the time On my inspire hr i clicked on my picture in the top left corner and then you scroll down until you find advance settings
Best Answer02-06-2020 06:48
02-06-2020 06:48
The gear icon does not seem to show up if you are using Internet Explorer. It does show up if you use Chrome.
Best Answer08-06-2020 15:13
08-06-2020 15:13
same here
Best Answer08-07-2020 07:23
08-07-2020 07:23
It might be different from one device to the other. I have Android. If you touch the distance icon on the home screen, the gear is in right corner of next screen. Hope this helps
Best Answer08-18-2020 16:07
08-18-2020 16:07
What do you mean by "on the web"?? WHERE on the web? Please be specific. I can't find the gear icon on my iPhone fitbit data or on my fitbit dashboard. This is driving me crazy. It all just keeps going in circles and the icon never appears in any places I've had suggested...
