06-04-2016
03:46
16:59
06-04-2016
03:46
16:59
06-04-2016 04:47
06-04-2016 04:47
Hi @MrsNycum
Feel free to check out the product care page:
http://www.fitbit.com/productcare
Hope it helps
Best Answer06-20-2016 08:08
06-20-2016 08:08
I had my fitbit 4 months and my wrist did the samething.
Best Answer06-21-2016 14:04
06-21-2016 14:04
@shelias Welcome to the Fitbit Community! Did you checked the Product Wear and Care Guide? You will find ways to prevent this from happening. Did you did something else?
Keep us posted! ![]()
Best Answer10-20-2016 09:10
10-20-2016 09:10
I'm have little bumps on my wrist where I wear my fitbit I have cleaned it and I still have them
10-20-2016 09:50
10-20-2016 09:50
@lizmarler Welcome to the Fitbit Community! That's unfortunate! I recommend checking the Wear and Care Guide to get some tips to keep your skin healthy. If the bumps remain, please stop using the device and contact customer support to get further assistance on this matter.
Let me know how it goes! ![]()
10-20-2016 10:05
10-20-2016 10:05
Best Answer11-15-2016 13:41
11-15-2016 13:41
@lizmarler I hope you're doing well! Yes, there are other bands made out of different materials. The problem is that these bands are available for the Flex 2, which is one of the newest Fitbit trackers that is replacing the Flex. You can get a bangle or pendant made out of metal. Click here to check it out.
Additionally, you can find leather and metal bands as well for the Fitbit Charge 2, Alta, and Blaze.
Let me know what you think! ![]()
Best Answer12-08-2016 05:31
12-08-2016 05:31
I've had a Fitbit since February 2015. The first band made me break out but as soon as I got new bands online with less nickel in the clasp, it was ok. I replaced it recently and my wrist is breaking out so badly, I can no longer wear it. I have washed the band, replaced the clasp and still no luck. This time I seem to be breaking out from the band, not the clasp. A two inch rash is going all around my wrist and the itching and swelling is terrible. I had to throw away the old band as it was splitting. I have talked to many people with similar problems and they have bought new bands off the internet. I truly believe Fitbit needs to take a closer look at this problem so that the product they offer can be used without problemsFitbit Flex Rash
12-08-2016 06:20
12-08-2016 06:20
@Ginasfit Welcome to the Fitbit Community! Thanks for your feedback and for sharing the picture. I recommend checking the Wear and Care Guide to keep your skin as healthy as possible.
Also, report the problem to customer support to get further assistance on this matter.
07:23
07:26
SantiR
12-08-2016
07:23
07:26
SantiR
Hello,
I've been through the wear and care guide from top to bottom. No relief
Gina Alexander
Moderator Edit: Removed Personal Information
12-08-2016 08:12
12-08-2016 08:12
@Ginasfit Thanks for your reply and for checking the Wear and Care Guide.
The best thing to do in this case will be to report the problem to customer support to get further solutions to this problem. If the problem persists, stop using the device!
Keep me posted!
Best Answer12-08-2016 09:09
12-08-2016 09:09
You may have a latex sensitivity. Make sure that the band isn't on too tight. If air can't circulate moisture gets trapped underneath and can irritate your skin. I found some leather watch band style bands online. You could try looking for replacement bands made from other materials. Good luck!
Best Answer08-04-2018 20:26
08-04-2018 20:26
My left wrist started breaking out but mine itches. I put my fit bit on my right hand now it to has started breaking out.
08-05-2018 05:44
08-05-2018 05:44
Best Answer08-05-2018 05:58
08-05-2018 05:58
Did the new band fix your problem?
Best Answer08-05-2018 12:58
08-05-2018 12:58
Best Answer08-06-2018 07:35
08-06-2018 07:35
@lizmarler wrote:
For a little bit know it started again .
Sent from my Samsung Galaxy , an AT&T LTE smartphone
It sounds like you are having an allergic reaction to the band. Have you tried purchasing 3rd party bands?
one cruise ship at a time!
Best Answer08-07-2018 10:50
08-07-2018 10:50
Hi there @Holmessam. I'm sorry that this is happening to you but I've escalated your case to the Support Team for them to help you out. Keep an eye on your inbox for more instructions and if you need anything else, I'm always around.
Welcome to the Forums. Let me know if you need more help!
Best Answer12-31-2018 09:48
12-31-2018 09:48
My wrist is breaking out too. I clean it and even purchased a brown band thinking it was the black rubber type of band that was causing the irritation. The new band is doing the same thing, it’s itchy and red bumps. I ordered a metal and bead band, I have not received yet. But I sure hope this solves it. It’s costly to purchase more bands!
