10-28-2017 13:34 - last edited on 08-20-2020 16:59 by MatthewFitbit
All of a sudden these lights are going back and forth non stop. Ive called fitbit and they sent me instructions to fix the problem. When you stick a paperlip in the hole on the charger what is supposed to happen?? Ive done that and proceded to do an update. So the tracker is back in my wristband, lights still going back and forth, and im wondering does the sync dongle need to be in my laptop??
DO I need to update on my laptop (where the dongle is) ? or can I do it on my phone which has the fitbit app? (not an iphone)
any help would be great
10-29-2017 10:17
10-29-2017 10:17
@suemacfit Welcome to the Fitbit family! I have seen a problem in which Flex tries to update, but it gets stuck. I think you may be experiencing this. In order to fix that, check the instructions on this post. That workaround has helped other users in the past and I think it will help you as well.
The update is for your Flex, so no need to update your laptop. Also, the dongle doesn't need to be on the dongle, best thing is that you do this process on a mobile device.
Please try that out and let me know how it goes!
10-29-2017 13:24
10-29-2017 13:24
10-31-2017 17:44
10-31-2017 17:44
Mine is doing exact same thing
11-01-2017 07:34
11-01-2017 07:34
@suemacfit Thanks for your reply! What you accomplish using the paperclip method is a restart on your Flex. This is a needed procedure to fix the problem you are experiencing. However, this is not the only procedure to do in your case. Please do all of the following in the posted order:
@ChrisB1987 It's great to see you in the Fitbit Community! Please try the above workaround to fix the issue you are experiencing.
Keep me posted!
11-01-2017 08:06
11-01-2017 08:06
11-04-2017 16:42
11-04-2017 16:42
Nobody has answered my last email
11-05-2017 08:12
11-05-2017 08:12
@suemacfit Thanks for your reply! When you restart your Flex the lights should quickly turn off and then blink again (as it shows when charging). This happens very fast! You can then follow the next steps I posted above to fix this.
Try that out ad let me know how it goes!
07-23-2020 06:03
07-23-2020 06:03
I am having the same problem. I have reset flex several times and turned bluetooth on and off...nothing..still scrolling lights and cannot pair. I removed it and am trying to pair it again..still no luck
