05-29-2015 07:46 - last edited on 08-20-2020 16:59 by MatthewFitbit
My fitbit switched to diplaying calories instead of steps. I have everything set up to display steps, but it is not showing steps. How can I get it to go back to displaying steps? Any help would be appreciated!
05-30-2015 09:34
09-20-2016 19:44
09-20-2016 19:44
No "Daily Goal Progress" to be found anywhere at that web site.
10-12-2016 09:42 - edited 10-12-2016 09:45
@morav Welcome to the Fitbit Community! Click here to have access to the device settings to have access to the daily goal progress. I left a screen shot showing how it looks!
Hope this helps. Let me know how it goes!
10-12-2016 10:41
10-12-2016 10:41
I see this when I am in my dashboard but cannot see it on my app even though in my dashboard I have chosen the step tracker tile...ugh
10-13-2016 07:23
10-13-2016 07:23
@psesar Welcome to the Fitbit Community! This option is not available on the Fitbit app for iOS devices. On the app you will be able to see your goals separately and change them.
To select an specific goal for your tracker to notify you once it is reached, you will need to make the change on your device settings on the online dashboard. Once you do that you will need to sync your tracker for it to be effective.
09-15-2017 13:29 - last edited on 09-17-2017 07:57 by SantiR
Me too! Can't get it to change back to steps! Ugh 😞
Moderator Edit: Format
09-17-2017 08:03
09-17-2017 08:03
@bmang20 Welcome to the Fitbit family! Do you see the steps tile at all? If you do, you can hold and drag it to the top for it to show as the main tile.
If you don't see it at all; it may be hidden. Follow these steps to get it back!
If possible, please send me a screen shot of your dashboard. That way I can see it and find a solution for you.
Keep me posted!
10-02-2017 22:36
10-02-2017 22:36
With daylight savings in Australia my fitbit flex changed to calories and I want it back on steps. Please help
10-03-2017 12:05
10-03-2017 12:05
@Fourlongs Welcome to the Fitbit family! I recommend checking if the step tile is hidden on your app's dashboard. Check this post to get the instructions on how to do that.
Also, if you do see the step tile, but it is not the main tile; you can tap hold and drag it to change its position to the main data tile.
Try that out and let me know how it goes!
05-08-2018 11:27
05-08-2018 11:27
I know this post is old, but im having this problem as well. I clicked on the link you provided and it shows steps as my goal, but on the app it still shows calories as the main goal. Any suggestions? Thank you.
10-10-2018 12:04
10-10-2018 12:04
Welcome to the Fitbit Community! Welcome to the Fitbit Community! Welcome to the obtuse Fitbit Community! Ha! 🙂
03-26-2019 07:54
03-26-2019 07:54
My charge 2 is showing calories on my record, I want a record of my steps.
03-30-2019 12:08
03-30-2019 12:08
I dont own a fitbit device. I use my phone. I carry my phone with me at all times. And now my fitbit account on my ios is not showing my steps, its only counting cal’s. “Screenshot” was an error.
I tried what u suggested over there, the link u shared, but it says that i should have a fitbit device. Is there anyway i can like make it count my steps instead of calories??
08-18-2019 07:55
08-18-2019 07:55
My fitbit charge 3 is only showing calories and not steps. Please help
10-07-2019 15:08
10-07-2019 15:08
Mine is doing the same. I’m getting a bit fed up with Fitbit , what’s going on
10-14-2019 14:59
10-14-2019 14:59
Try going to edit and unselecting everything on the display and then re-select. This happened to me and I was able to reset successfully!
10-14-2019 15:02
10-14-2019 15:02
Did you get it fixed? This happened to me and I went to edit and unselected everything on the display and then went back in and reselected and it reset successfully for me!
10-14-2019 15:03
10-14-2019 15:03
12-01-2019 18:46
12-01-2019 18:46
Go into Account. Then click your device. Under General, click on Main Goal. Somehow my hubby's was changed to Floors. This is how he put his back to Steps. Hope it works for you.
