02-28-2015 10:15 - last edited on 05-23-2023 10:10 by ManuFitbit
Hi there- I've lost my fitbit but it is still syncing to my phone. Does anyone have any tips on how to narrow down where it is? Thanks!
Moderator edit: clarified subject.
05-07-2018 05:44
05-07-2018 05:44
Hello @MSW1013, I hope you're having a great day, thanks for joining the Fitbit Community!
I would like to thank you for sharing your experience with me, I'm very glad the app you used was helpful to find your lost Fitbit, I'm sure it will be very helpful for many members of the Community as well.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
06-01-2018 02:12
06-01-2018 02:12
Getting the light blue app helped me find mine when I misplaced it
06-01-2018 17:01
06-01-2018 17:01
Thanks, Jojaz17! I lost my Fitbit One (pretty retro by now but I’m attached to it). I read your post, downloaded LightBlue and used the blue bars and located my One. Thanks!!
07-16-2018 08:23
07-16-2018 08:23
Having read these comments, I tried BlueLight; and it was if no help. It located the signal from the Alta, but did not point to it's locatikn. The bars and decibels responded sooo slowly, and seemed to show no progression towards the Alta. It also kept shutting itself off so I had to tap the refresh icon wait , wait, wait, and then get a different readjng than previously in the same spot.
The app that worked was the free Bit-Finder Geo. It responded clearly in seconds, pointed me right to the Alta. Yay!
07-17-2018 03:34
07-17-2018 03:34
Couldn't remember how to find...found within 5 seconds of setting alarm....ty!!!
09-03-2018 06:58
09-03-2018 06:58
Just wanted to let you know that your post saved me from having to replace my Fitbit. I set the alarm and it had fallen into our trash can next to where I normally put it. Had I not set the alarm I wouldn’t have heard it and my Fitbit would be on the way to the dumpster. Thank you!!!
09-03-2018 19:19
09-03-2018 19:19
09-08-2018 09:19
09-08-2018 09:19
Thanks for telling that found my surge on my brother’s wrist
09-08-2018 12:48
09-08-2018 12:48
12-06-2018 23:37
12-06-2018 23:37
If your fitbit is synced still, set an alarm. You’ll definitely hear it vibrate.
01-23-2019 12:23
01-23-2019 12:23
Yeah. Used the alarm feature and found my Fitbit One. This option should be more front and center in the Help feature. Do you hear that moderator...please!?
02-10-2019 09:32
02-10-2019 09:32
I thought I'd lost my Charge 2 but when I tried to sync it with my phone, the app was finding it...but where? The guidance here was invaluable - my phone is Android so I installed the Bluetooth Finder and bingo, it immediately detected it. The signal grew as I got nearer making it easy to find.
Can't speak highly enough of the Fitbit Help article or of the suggested app. THANK YOU.
03-12-2019 17:12
03-12-2019 17:12
How’d you do that on your phone... please add details thanks!
03-13-2019 00:22
03-13-2019 00:22
Click on the link in my response - this takes you to a page with links to download apps (in my case it was the app for Android via Google Play Store). Once installed on your phone, activate the app to search for any Bluetooth devices. You can test it's working by using another Bluetooth device - it'll find it! Then it should pick up your Fitbit. The bar in the app gets bigger as you get nearer so it's pretty intuitive - just wander about seeing whether the bar gets bigger or smaller and it'll lead you to it. Not sure about the app's range - if your Fitbit doesn't register on the screen straight away, maybe start new searches in different locations. Hope you find it.
04-08-2019 12:38
04-08-2019 12:38
Hi do you know if the app light blue works if Fitbit has run out of battery? Thanks xx
04-08-2019 12:58
04-08-2019 12:58
04-08-2019 15:31
04-08-2019 15:31
04-08-2019 15:48
04-08-2019 15:48
05-13-2019 10:06
05-13-2019 10:06
THANK you so much for this. Found it via this app.
05-14-2019 14:43
05-14-2019 14:43
