02-19-2016 00:39 - last edited on 08-20-2020 16:59 by MatthewFitbit
I bought my Flex 2 months ago and today it suddenly stopped working - when I tapped it, no display lights came up. The battery was low so I recharged it (which appeared to be successful as all 5 lights were flashing after a few hours in the charger) but when I put it back in the band, the display lights still aren't working and now it won't sync with my iPad either. I have tried resetting the Flex several times, following the website instructions, but without success. I even tried resyncing it following the troubleshooting instructions, but that didn't work either. I noticed when I put the Flex into the charger, that a pattern of 4 solid lights appears (the one in the middle doesn't come on) before it starts charging. The same light pattern appears briefly after each reset attempt as well. Has anyone has this issue where the Fitbit has started working again or did you have to get your Flex replaced?
I bought it from a retailer here in Australia who is now in voluntary administration, and am worried that I probably have little or no chance of getting the Flex replaced by them. I have emailed Fitbit Customer Support, so am hoping they will be able to help.
02-22-2016 07:38
02-22-2016 07:38
02-22-2016 13:22
02-22-2016 13:22
Aloha Julie 50! Thanks for much for posting your info on your fitbit! Same thing happended to mine this morning, same 4 lights & not working. I called in & referenced your information detailing the same thing happened to mine & replacement is on it's way. I did ask if there is a reason for the fitbit to stop working & was asked it mine had gotten wet (No) or if we had attemped to charge it in a wall outlet (No), those two were the only possible reason they knew of that may of caused it to suddenly stop working.. anyway, thanks again for your post it assisted greatly in expediting this process of getting a replacement! Mahalo, Joseph
02-22-2016 23:54
02-22-2016 23:54
Aloha Joseph! I'm pleased to see my post has helped someone else and glad to hear Fitbit are replacing your Flex. No, mine didn't get wet either (I've been extremely careful to avoid that happening!) and I was using an iPhone USB charger to recharge it, so neither of those reasons was the cause for mine to stop working.
02-23-2016 00:38
02-23-2016 00:38
03-27-2016 04:13
03-27-2016 04:13
My daughter's flex is having exactly the same issue. Still waiting for response.
04-06-2016 06:44
04-06-2016 06:44
04-06-2016 07:03
04-06-2016 16:01
04-06-2016 16:01
05-04-2016 12:19
05-04-2016 12:19
I too have had these problems. I purchased mine 10 months ago. The first one worked 4 months. After that FitBit replaced it three times, only to have the same thing happen time after time. Yes I did all of the things they suggested, but still didn't help. I tried uninstalling the program and reinstalling. It helped for awhile. I even offered Fitbit to send them back my Flex so that their tech people could find out the problem, but they weren't interested. Interesting enough I took it off for several weeks and decided one day to put it back on, and to my amaizement it worked for quite awhile. Then it stops. From what I can tell, whenever I let the battery get realy low, is when it starts having problems. I will leave it off for a week, then try it again. Hope this helps.
05-04-2016 14:53
05-04-2016 14:53
I had my Flex for 6 days. It has worked beautifully until I decided to charge it this morning. I used the dongle attached to my Surface. Afterward I put it back in the band, I got nothing. It won't sync to my iphone. No lights. Nada. This evening, after reading this thread, I put it back in the dongle to see what might happen and it synced with the iphone. I replaced it back in the band and nothing. It's never been wet. This was its' first charge after the first use. Very dismayed!
05-08-2016 17:52 - edited 05-09-2016 15:14
@mashowman & @bloodymary1 welcome to the forums! Hey, guys have you tried restarting your trackers? To do so, follow these steps:
Try to sync again and let me know how it goes!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
05-08-2016 18:22
05-08-2016 18:22
05-09-2016 15:41
05-09-2016 15:41
@bloodymary1 thanks for getting back to me! Our Support Team is indeed wonderful and they definitely know how to take care of our customers! When you receive your replacement Flex, follow this steps to set it up to your existing account:
Feel free to post back!
05-10-2016 10:54
05-10-2016 10:54
05-11-2016 14:42
05-11-2016 14:42
@mashowman thanks for getting back to me! By what you're describing, that doesn't sound like normal behavior and at this point I'd recommend contacting our Support Team for a second opinion. They have the proper tools to take a deeper look into your tracker's behavior. Also, when you contact them let them know about the troubleshooting steps you've performed to fix your Flex. That will help our Support Team to properly follow up with your case and to get to the bottom of this as soon as possible. I wish you the best of lucks and I'll keep my fingers crossed for your buddy! Keep me posted with the outcome on this, I'll be around!
05-12-2016 03:38
05-12-2016 03:38
05-15-2016 16:47
05-15-2016 16:47
@bloodymary1 thanks for getting back to me and for the update about your replacement tracker. I definitely see where you're coming from and your feelings are totally valid. However, in order to get a more specific update on your order status, I'd recommend contacting our Support Team. Make sure you provide them with the confirmation number so they can quickly find your order. Wish you all the best with your order. I'm sure there's an explanation for this. I'll keep my fingers crossed!
06-10-2016 04:31
06-10-2016 04:31
Help--flex fully charged but somehow has been disconnected--2nd day I cannot use-battery is fully charged & changed bracelet-any help would be appreciated
06-10-2016 16:45
06-10-2016 16:45
06-16-2016 02:46
06-16-2016 02:46
So... did anyone getting the mysterious light patterns while recharging (all five lights except the middle one just before it recharges) find a solution? Recently my fitbit stopped working out of the blue, and was replaced. But now my replacement fitbit after just 3 weeks has done exactly the same thing... says it is recharged (after the flashing lights - all 5 except the middle one), but once it is on my wrist - nothing!! I've tried the reset - multiple times - nothing. I'm happy to replace my fitbit, but want to know that my third won't have the same issues after just three weeks...
