05-06-2015 16:41 - last edited on 08-20-2020 16:59 by MatthewFitbit
my steps in the work week challenge are not registering correctly. It seems to be caught by 2/3rds. The single day challenges reflect the same number of steps as the dashboard. This is getting frustrating as I look my of a loser than in just weight 😭 help!
05-07-2015 11:38
05-07-2015 11:38
Welcome to the Fitbit Community @pbrennan and @jjkbe00!
Challenges can be affected by the timezone of the members who are in it as well as any logged activities on your account, this includes MobileRun, manual logs and third party logging).
In this case, it's best to use your tracked steps (without mobile run or manual log) while stepping. Using any kind of manual logging when running or walking will not count towards your challenges.
Hope this helps! Let me know if you have any questions
05-06-2015 20:23
05-06-2015 20:23
05-07-2015 11:38
05-07-2015 11:38
05-17-2015 09:37
05-17-2015 09:37
I didn't use any 3rd party app, and my step on the dashboard says just over 10k and the goal daysays I only got 59%. I used the activity tracker on Fitbit. So does that mean my steps didn't count toward the Fitbit Goal Day?
05-21-2015 16:12
05-21-2015 16:12
Hi there @yasashiokaasan, Welcome to the Fitbit Community! It seems that you used your MobileRun feature on your mobile app. Fit has made some changes in the way it tracks, please take a look at this thread where some of our Moderators published an official announcement.
07-14-2015 08:44
07-14-2015 08:44
Okay .. I only walk .. My fitbit one for today so far says 5480 steps .. my fitbit for yesterday said (at the end of the day) 22835 .. this is what is on my dashboard. I invited others to the Weekday Hustle .. starting yesterday at midnight my time (East Coast USA) .. when I go to the Challenge Board .. my total says 24,786 .. which is 3529 steps short .. is there a delay in updating the Challenge Boards? Or are we being 'robbed' of steps?
07-15-2015 08:52
07-15-2015 08:52
Welcome to the Forums @gayleginOh! Here some possible reasons for this:
- Steps are not able to see this steps, because the app is on Live Data Mode.
- You could be manually logging steps or using MobileRun. (Only steps recorded by your tracker or MobileTrack are counted toward challenges).
- Challenge participants are not in the same timezone as the creator of the Challenge.
- The battery level on the tracker is low.
To check if you have disabled the Live Data Mode on your app. You need to go to account, then tap the picture of your tracker and scroll down and disable this option. Also, you can try to log out from the app and log back in.
I hope this helps!
07-15-2015 09:26
07-15-2015 09:26
Hello-
So I'm having a similar problem: my daily steps are not all being added to the workweek hustle challenge. Am I understanding your last response correctly in that if I use a third party app to track my run (or walk) and then log it into my fitbit, it will not count for the challenge?
Thanks.
08-01-2015 13:24
08-01-2015 13:24
08-01-2015 20:09
08-01-2015 20:09
08-03-2015 04:52
08-03-2015 04:52
You're right @Meag84, only the steps recorded by your tracker itself or MobileTrack will be counted for challenges, any other app or MobileRun won't.
Have you checked the steps I've provided here @Newbie923?
Hmmm...if you have checked everything, would you mind trying to log out and log back in @ushergyrl04?
P.S. I'm glad you joined us in thread @ushergyrl04 @Newbie923 !
08-31-2015 02:30
08-31-2015 02:30
Hi everyone,
It seems like this is a fairly common problem... I have been part of several challenges. Some have worked, many have not. I live in Milan so my time zone is almost always different from other competetors... but there are others from Milan in the same challenge who have no problem.
For example, today I've done over 4000 steps and it registers as 690 for the challenge!!! How can I solve this problem???
Thanks in advance!
09-24-2015 18:35
09-24-2015 18:35
09-25-2015 06:05
09-25-2015 06:05
Welcome to the Fitbit Community @Flexdebtx @morganrobinson! Below are possible reasons for this issue:
1. Steps have fully synced to our database and you are not viewing the mobile app dashboard in Live Data Mode. (Live data mode would show the word "connected" under your tracker tile).
2. You are manually logging steps. (Only steps recorded by your tracker or MobileTrack are counted toward challenges).
3. You're using Mobile Run (GPS Run tracking feature in the app) and you did not wear your tracker. (The steps recorded through the GPS run feature are not counted toward challenges.)
4. All challenge participants are in the same timezone.
5. If the battery level on your tracker is low, charging the battery will ensure additional steps earned will be added to challenges.
Please see our Challenges FAQ for more information go here.
Have a nice day guys!
09-25-2015 06:41
09-25-2015 06:41
Hi Maria,
1. Yes, shows connected.
2. I am not manually logging steps.
3. I am not using the Mobile Run feature.
4. I am in a different time zone, but for the week so far I have 19k steps, its only giving me challenge credit for 2k steps. (I am Central, other participants are Pacific.)
5. Battery is full.
It's Friday, how long does it take to sync the challenge steps? I get notifications that people have made goals, so it seems like it updated constantly. Like I said, I've been having this problem for months. Any other suggestions would be greatly appreciated.
09-25-2015 06:59
09-25-2015 06:59
Many thanks for getting back to me @Flexdebtx, it seems that the different timezone may be affecting your steps into the Challenge.
The challenge begins and ends in the challenge owner's timezone, so if you're in a different timezone than the challenge owner, you may notice that your challenge leaderboard stats do not always match your dashboard stats.
However, I'd like you to contact Fitbit Support directly. So they can do a deeper investigation into your account and figure out where this issue is coming from.
Good luck sweetie!
09-29-2015 07:51
09-29-2015 07:51
I'm frustrated by this. If i walk on my treadmill and log that manually, it is not matching what's on my dashboard to what the "challenge" total is. why would it not be the same? i'm sure that putting that information in wouldn't be considered cheating. I'm walking for say a mile, and manually logging that for accuracy. ridiculous. really this is my only complaint about how FB works. i want to be able to log my treadmill steps for accuracy.
09-29-2015 08:38
09-29-2015 08:38
Thanks for joining this thread @HippieJen16! I can't imagine how frustrated this might be. However, there's not way your steps logged from the Treadmill activity be included on your "Challenges" since at the moment this is the way the Challnges work.
Thank you for your suggestion. We're constantly striving to improve Fitbit products and services, and we very much appreciate all of the input we receive from our customers. The best place to make your voice heard is the Ideas board on our community, which our product development teams consult regularly to ensure we're delivering on what our customers need and want. Please take a moment to visit and give us your feedback.
If you find that a similar suggestion has already been made by another member of the community, you can vote for their idea and add your comments. Our product team looks forward to reading and incorporating your suggestions into future versions of Fitbit trackers and apps.
Have a nice day!
11-07-2015 05:43
11-07-2015 05:43
11-07-2015 08:42
11-07-2015 08:42
It's great to have you here in the Fitbit Community @Wedwo , welcome on board! At this time only steps from your tracker count towards the challenge, the steps you manually logged don't count towards it. I'd like you to check the Challenges FAQ article to see all the information about this darling.
Have a blessed weekend!
