05-06-2015 16:41 - last edited on 08-20-2020 16:59 by MatthewFitbit
my steps in the work week challenge are not registering correctly. It seems to be caught by 2/3rds. The single day challenges reflect the same number of steps as the dashboard. This is getting frustrating as I look my of a loser than in just weight 😭 help!
05-04-2016 11:09
05-04-2016 11:09
Thanks RebeccaR2, I took your advice. I can't imagine what new secret they'll be able to share with me, since I've followed all typical online advice. From reading how many people have this problem I have to admit it doesn't sound very promising.
05-04-2016 11:33
05-04-2016 11:33
05-04-2016 20:07 - last edited on 05-15-2016 10:17 by HelenaFitbit
I am running and walking. I run the same loop every time. The fitness tracker on my dashboard on the phone app records the mileage correctly. Then when I sync my wristband to the app on my phone it will reduce my steps down to go off my wristband rather than my phone app. It's ridiculous! I have convinced myself that I am being foolish by worrying, but isn't that the purpose of the fit bit tracker? To motivate us to get in more steps!? At this rate, I don't even want to wear my fit bit tracker when I exercise because it does not record things correctly. And yes, I have three started it, it is always charged, and everything else shy of just simply returning it to the store. Got out my box tonight and found my receipt.
Moderator edit: Removed personal information and email signature.
05-05-2016 03:31
05-05-2016 03:31
05-05-2016 03:46
05-05-2016 03:46
05-05-2016 06:03
05-05-2016 06:03
05-05-2016 13:32
05-05-2016 13:32
I am a little curious as to how a low battery would matter for challenges? If it is low, yet still has enough of a charge, and is still tracking the steps accurately, how would that affect the challenge steps? It does not make sense. For example, my battery is low but it is tracking every single step on my dashboard yet on a challenge it says i have only done a quarter of what i actually have done.
05-05-2016 16:44
05-05-2016 16:44
05-10-2016 20:21
05-10-2016 20:21
Helena, all of what you've stated is true. However, there is something else going on with the syncing feature. My Fitbit HR has not been syncing correctly since last week. Nothing has cjanged on my end...timezone, friends and manual logs are constant.
I read where Fitbit is having "an issue" and doing their best to correct the problem.
I wish they would hurry! This is getting very frustrating!!
Does anyone know if there is a way to reset or refresh my Fitbit HR tracker? Maybe this is all I need to do, if there is the option.
05-10-2016 21:55 - last edited on 02-07-2021 18:56 by LiliyaFitbit
From a time when I had a problem the fitbit group replied that I should hold the button down for three seconds or more to try to reset my fitbit.
Sent from my iPhone
05-11-2016 08:15 - last edited on 05-15-2016 10:16 by HelenaFitbit
I ended up returning my Fitbit HR after 2 months of frustration. Moved on to a different brand.
05-11-2016 11:35
05-11-2016 11:35
05-12-2016 05:08
05-12-2016 05:08
05-15-2016 04:26 - last edited on 06-21-2016 10:21 by SantiR
I have a Fitbit Flex. I followed your info on Live Data Mode and didn't see any such option. I had almost 15,000 steps yesterday on my Dashboard, but in the Weekend Warrior challenge it only shows 2400. Aargh! The challenger is on Pacific time, but still, it's the next day now & my steps aren't showing up. So frustrating.
Moderator Edit: Format
05-15-2016 04:29 - edited 05-15-2016 04:32
I have the exact same thing going on. Maybe there's something weird about living in Texas?
05-31-2016 07:07
05-31-2016 07:07
05-31-2016 07:49
05-31-2016 07:49
06-07-2016 10:55
06-07-2016 10:55
why is this the case? makes no sense... is there a way to manually force it to upload into the challenge?
06-07-2016 11:04
06-07-2016 11:04
06-20-2016 18:41 - last edited on 06-21-2016 10:22 by SantiR
No, this is not helpful. It seem like everyone is having the same problem....multi-day challenge....only use tracker, nothing else, no manual logging....everyone in the same timezone...tracker is charged. But you keep telling us that one of those issues is the reason we're having problems. I am in a multi day challenge, in the same timezone with all the participants, my tracker is charged, and I only use the tracker (I don't manually track). Why is my step count so much lower than what is on my dashboard? How do I fix it?
