05-06-2015 16:41 - last edited on 08-20-2020 16:59 by MatthewFitbit
my steps in the work week challenge are not registering correctly. It seems to be caught by 2/3rds. The single day challenges reflect the same number of steps as the dashboard. This is getting frustrating as I look my of a loser than in just weight 😭 help!
09-26-2016 14:20 - last edited on 10-02-2018 13:10 by SantiR
Update:
I disconnected 3rd party apps MapMyRun (and all the associated ones with MapMyFitness) and deleted MyFitnessPal completely from my iPhone because it kept connecting to the Fitbit app.
I did over 13,000 steps today, it registered under the steps and not the exercise activity section.
Unfortunately, the steps did not sync in the challenge (Workweek Hustle). It read 1318 steps.
I called Fitbit customer support, who tried to help by asking me to restart the Fitbit.
I've restarted the Fitbit (by connecting it and pushing a paper clip into the charging cable that was plugged into an active USB port.)
It rebooted the Fitbit, and reset my steps form 13706 to 1470 on my Dashboard.
Synced again, the challenge registered 1382 steps.
I quit the challenge and asked one of the participants to add me again, the steps still show 1382 (and my dashboard for today still says 1470.)
So, my theory about the 3rd party apps being the conflict does not appear to be the case.
At this point, the issue has been escalated to the tech department. I will update again when I hear from them.
Moderator Edit: Format
09-27-2016 06:34 - last edited on 10-02-2018 13:10 by SantiR
I went through the same thing with two Fitbits. I have returned both and moved on to the Apple Watch :watch:️.
Moderator edit: Removed personal information/format
09-28-2016 08:22
09-28-2016 08:22
11-21-2016 20:20 - last edited on 10-02-2018 13:10 by SantiR
Let's admit it, Fitbit! It's a chronic bug! I'm returning mine!
11-29-2016 11:51
11-29-2016 11:51
Have there been any updates on the challenge sync yet? Mine has always worked until the last two weeks or so. Now my challenge steps are not the same as my dashboard. I have not changed the way I do anything and do not log activities, strictly the steps I take as calculated by fitbit. Challenge is in a different time zone, but only by 1 hour (shouldn't make a 15K step difference).
Side note, does anyone know how to see challenges on the website?
11-29-2016 22:22
11-29-2016 22:22
12-05-2016 11:27
12-05-2016 11:27
Kreitz
Hello, im having the same problem my dashboard shows 10886 but my workday hustle only shows 6368
Im not manually logging my steps
Im in the same time zone
And my battery is fully charged
12-06-2016 20:58
12-06-2016 20:58
I had to charge my Fitbit flex and took my nightly walk on my treadmill and logged it my extra 10,000 steps manually, but when I looked at the challenges I am in with my friends it didn't show that I was ahead of one of my friends. Why can't my manual logged activity reflect my steps in the challenges. That is not fair if I forget to put my Fitbit on, or need manually log in my activity to not reflect any of the challenges I am in.
01-14-2017 15:49
01-14-2017 15:49
I'm having the same problem and have tried all the advice below. Hence I'm losing interest in the challenges because my challenge does not record as many steps as the dashboard or the Fitbit itself. Any further advice is much appreciated.
01-14-2017 19:25
01-14-2017 19:25
01-16-2017 00:52
01-16-2017 00:52
I have the Fitbit flex 2. Was challenged to the weekend warrior. When I go into the challenge it shows all my steps. However, it says it's awaiting sync?
01-16-2017 14:55
01-16-2017 14:55
I'm having the same problem and it's becoming so frustrating
01-16-2017 16:01 - last edited on 10-02-2018 13:11 by SantiR
I've just given up and never participate in challenges anymore. I love my
FitBit but am frustrated with the company's utter lack of desire / follow
through to fix this widespread problem.
Happy stepping...
01-29-2017 11:28
01-29-2017 11:28
So if I read your answer correctly Challenges only count the steps from my Fitbit and not the activity I manually enter? That may explain why my challenge steps are always much lower than my dashboard numbers.
02-13-2017 21:17
02-13-2017 21:17
Here is a very simple fix to try if your dashboard shows a bunch of steps and your challenge doesn't.
Go into the challenge and tap the "options" in the top right corner. Change the "do not disturb" option. Close the options. It fixed mine.
02-20-2017 07:00
02-20-2017 07:00
Thanks Austin, that fixed mine too.
02-24-2017 06:57
02-24-2017 06:57
What is Mobile Track? Is that the fitbit mobile app?
02-25-2017 09:04
02-25-2017 09:04
I use a third party app (TravelBit) to erase "bonus" steps that are recorded by my Flex when I'm rocking in a rocking chair with my baby. My dashboard is accurate, but my challenges always include the extra steps that I clearly didn't take. How do I fix this?
02-25-2017 20:10
02-25-2017 20:10
This is really frustrating. Your devices aren't waterproof, and I can't accurately record steps I take when walking in the pool. I do this often, once a week or so, but because the watch isn't waterproof, I can't wear it. So I manually enter the steps using Fitbit and they aren't counted in challenges. This needs to be changed.
02-27-2017 13:07
02-27-2017 13:07
Hello I don't mean to repeat people in here but how is this a proper tracker if I clearly run 5 miles on a treadmill (usually sprints at high speeds followed by slow pace rests) and the fitbit only give me 3.5 miles in steps!? Seems kind of pointless to put in the work if I am not being logged correctly. Is it the speed? WTH?
