07-28-2015 19:37 - last edited on 08-20-2020 16:59 by MatthewFitbit
I have been using my flex for months now but noticed recently that it's not showing the mapped routes I walk. How do I get this back?
08-13-2017 13:35
08-13-2017 13:35
I used to be able to see my map/route and my pace for each mile, but now I can't. Can you please advise.
I have an iphone7.
I have the the most recent updates on my phone and Fitbit.
I just uninstalled and reinstalled Fitbit, still didn't fix it.
Thanks.
08-13-2017 14:45
08-13-2017 14:45
As with Jefna its the same for me. Desk top.shows it but not tje mobile. Just wonder if Fitbit monitors this feed????
08-13-2017 20:10
08-13-2017 20:10
This should help. I messed around with it and got it working again.
08-20-2017 17:03
08-20-2017 17:03
Hi EdsonFitbit,
I'm having the same issue with my fitbit. I have a fitbit blaze and I just went for a walk with it. I made sure the gps feature was on and tracking where I walked. At the end of the walk I was told my distance of 7km, my speed, and I also saw a map of the route I took. After going back to the activities page, the map was no longer there. I have restarted my phone. I have disconnected and reconnected my fitbit device, but the map of the walk has completely disappeared. Is there anyway that I can get it back?
Thank you very much for your help,
James
08-21-2017 00:51
08-21-2017 00:51
Still experiencing this same problem.
What i have discovered is the maps have been captured but only on the desk top computer. All very troubling.
Den
08-21-2017 00:54
08-21-2017 00:54
@JamesRhydderch wrote:Hi EdsonFitbit,
James
Den
08-21-2017 05:25
08-21-2017 05:25
What's happening to me now is when I start my walk I check to see that the little phone symbol is there without being crossed out but somewhere along my walk I lose connection and don't realize it until I end my walk and stop the activity. Very Frustrating!
08-26-2017 15:10
08-26-2017 15:10
My charge 2 started doing this last week. I've uninstalled reinstalled rebooted. Notta sorts it out. It doesn't show up on my phone or computer. It's getting me very flustered.
08-26-2017 17:09
08-26-2017 17:09
Go to settings, then Fitbit and make sure your location setting is turned on.
08-27-2017 16:53
08-27-2017 16:53
11-20-2017 05:30
11-20-2017 05:30
Turn onn your location or gps in your phone setting
11-20-2017 06:03
11-20-2017 06:03
Mine still does not work. Now changed my phone and its still an issue - its providing audible confirmations of elapsed distance etc but at the end no map or summary... I am becoming frustrated and suspect its a failure of the bluetooth because no one can see by Fitbit with Bluetooth....now with a new phone I have removed the final argument --- must be a year plus soo disappointing. too many of us having the same problem!
01-04-2018 10:05
01-04-2018 10:05
Hi, how did you get your maps back please?
01-04-2018 10:19
01-04-2018 10:19
01-06-2018 07:07
01-06-2018 07:07
I called the help desk and they went through a lot of testing. Cut a long story short it was agreed that the bluetooth had failed.
THey offered me a replacement proposal which I accepted.
All is working well BUT it does seem that on my Samsung S8 I no longer can view the map link BUT it does record it on the desk top. I need to do some more testing to see what is happening.
BTW I tried removal and reloads etc and completed these when I made the help line call.
01-28-2018 04:02
01-28-2018 04:02
I have a fitbit but for the ladt few days it is not plotting the route. I went on the pc and aldo there it is not plotting. Shows each run with steps, distance, duration, calories, hart rste, etc but not the route. It used to show but just stopped
01-28-2018 04:09
01-28-2018 04:09
wrote:@Jeffna Thanks for the update. I would like to confirm you are looking for your maps by following this path:
Go to your Dashboard, select "Track exercise", scroll down to locate your recent activity which should show the map and tap on it.
If your mobile device still doesn't show your maps, please provide me with the following information to further investigate:
- What type/model of mobile device are you using?
- What software version is it running?
- Were your maps showing previously?
Looking forward to your new comments.
01-28-2018 11:50
01-28-2018 11:50
01-28-2018 12:02
01-28-2018 12:02
I have an S8 and since I uninstalled and then reinstalled the app its been fine.
05-26-2018 12:48
05-26-2018 12:48
Same problem here.
