06-08-2015 12:25 - last edited on 08-20-2020 16:59 by MatthewFitbit
newbie to this and not getting why it consistently tells me im over my calorie budget at the same time as it says i have a couple of hundred calories left?my output is way over my input too.any thoughts?
01-18-2017 15:54
01-18-2017 15:54
"The Food Plan will work like this: The calorie deficit will be deducted from the amount of calories burned and those will be the calories that you're allowed to eat."
OMG, thank you. This paragraph FINALLY explains what I've been trying to figure out since I got my Fitbit. No other explanation made since! I've lost 15 pounds since mid October 2016 by staying in the zone or below it. It works!
01-22-2017 08:53
01-22-2017 08:53
I think the explanation that will explain it is on this thread. It's the one about how all those numbers change automatically at 6 a.m., at noon, at 6 p.m. and then midnight based on averages and not what you're actually eating.
02-02-2017 22:29
02-02-2017 22:29
I'm having the same problem. I finished dinner and I was over budget--I knew I would be. Then I worked out for an hour, burned most of it off so I could stay in the "green" but I still was 97 cals over. But when I was going to bed, the number of calories over had actually gone up! How? I didn't eat anything and I'd been doing household chores, walking up and down stairs, etc.
i relaly want want to use Fitbit to track calories to lose weight, and it's only a matter of 100 calories in this case, but if I don't know what I'm burning and if I'm in the target range, how can it work!? Anyone got tips?
02-03-2017 09:46
02-03-2017 09:46
02-06-2017 17:34
02-06-2017 17:34
Here are my screen shots too. I think the 193 remaining is from myfitnesspal while the graph is from fitbit.
02-09-2017 11:36
02-09-2017 11:36
Hi, I am still trying to figure this stuff out. I am using the "harder" category to lose 2 pounds per week with a 1000 calorie deficit. So on the gauge, am I shooting for under, on target or over? I need someone to put it in layman terms for me or draw me a picture...lol. Someone please help me out.
Thanks!
02-10-2017 03:02
02-10-2017 03:02
This is the first explanation that makes sense to me.
Thank you!
02-10-2017 14:11
02-10-2017 14:11
So I need to be under. Is that it??? This program is a lot better than the Everlast tracker. That has zero explanations!
02-13-2017 01:23
02-13-2017 01:23
The other day I burned 3500 calories and ate below 1500 (which is my goal). "2000 calorie" deficit and I was still in the red.... you're probably still going to get 0 explanations from Fitbit regarding the deficit issue.
02-20-2017 00:37
02-20-2017 00:37
Thank goodness for someone who has explained it clearly - it was driving me nuts! My only other challenge now is that last night I was 'in the zone' but this morning, it tells me that I was 'over' yesterday and not in the zone. How this can suddenly change is a bit strange....
03-06-2017 16:46
03-06-2017 16:46
How is it possible to be over budget with 185 calories left in my budget?
I don't get how I can set this to lose a certain amount of weight, it gives me a calorie budget for the day, I stay under that budget, yet the meter tells me I'm over.
03-12-2017 20:48
03-12-2017 20:48
Fitbit needs a simpler, user friendly method to show the input/output ratio of calories. This is not intuitive & has way too many variables. I am "over" everyday, but with exercise & a low calorie plan I am losing weight.
03-12-2017 20:57
03-12-2017 20:57
This is ridiculous !! If i burn more calories, the "over gap", however it's calculated, should go down. Right??? Seems not. The more cals i burn, the more my "over" calories go up ???. Fitbit, i looove my charge HR but this meter is not on point... At all.
03-14-2017 09:08
03-14-2017 09:08
The most confusing backwards interface possible. FitBit review all these messages and take it on board and change it instead of stubbornly trying to educate people on that which should be very straightforward.
03-14-2017 09:09
03-14-2017 09:09
Oh god way too much effort. This shouldn't be complicated! Fitbit sort it out!
03-14-2017 12:17
03-14-2017 12:17
Fitness Pal has better information & is much clearer to understand.
03-14-2017 16:02
03-14-2017 16:02
Thanks for asking this question. I'm having the same question. Is it good to be under, or good to be over, if you want to have more calories out than in?
03-14-2017 17:12
03-14-2017 17:12
Im sure youve already figured it out, but the calories left in your budget is just and estimate to what your activity level has been. What i focus on is just calories in and out. Because if you check the previous days end results thats all that is calculated..did you meet your projected calorie deficit amount...burned more than you ate or vice versa..i was killing myself trying to figure it out also...but at the end of it all its a matter of in versus out
03-14-2017 17:14
03-14-2017 17:14
03-14-2017 17:18
03-14-2017 17:18
It took me some time to figure that out as well...i wish they would do as you suggest or just remove it altogether and just post the final results the next morning...i just focus on in versus out..those extra calories burned i get later are like an added gift..
