05-24-2017 10:03
05-24-2017 10:03
I read through the article on how they are calculated-seems a bit convoluted but it is what it is.
What does the number on my dashboard represent? Are minutes 1-9 ignored? If I am active for 20 minutes am I awarded 2 minutes since it requires 10 minutes to count as active?
05-24-2017 10:41
05-24-2017 10:41
My understanding is if you exercise 11 minutes straight, you will get 11 minutes. You can get away with a short break, but I don't know how short.
05-24-2017 10:41
05-24-2017 10:41
You mean this help article?
If you're active for 9 minutes I assume you won't get anything for it, but if you're active for 10 or more you'll definitely get credit all of those minutes including the first 9.
I think the same is true for steps but I'm not sure where the threshold is for that. My Blaze kicks starts counting after around six as far as I know, but those first steps are also included in the count.
Most step trackers, even hip-based ones, does this as far as I know.
05-24-2017 11:14
05-24-2017 12:49
05-24-2017 12:49
Long enough to get my sweatshirt off and tie it on my waist, but that is it! 😄
