01-06-2014 15:54
01-06-2014 15:54
I went to the gym with my flex for the first time today. I'm not sure what I did wrong. I feel like the steps are wrong. I did the stationary bike for 25 minutes and the treadmill for another 25 minutes. I entered everything in to the activity log. I wanted to have a nice log of all the things I did at the gym, so I could follow the progress. Nothing showed up though. The very active minutes is still at zero. I did tighten the band earlier and it took forever for the two taps to bring up the LEDS. So, I put the band back where it was earlier tonight. It seems to be coming up better now. Any help with how to log things in would great. I want to make sure I get as much out of this as possible. Also, I hit the 5,000 steps and no badge. I'm hoping that tomorrow will be different.
Best Answer01-06-2014 17:36 - edited 01-06-2014 17:37
The fitbit does not count the stationary bike very well. It should the treadmill.
Also if you manually log steps you will not receive a badge. Badges are only awarded for true Fitbit Steps.
You might want to read the manual it can help as well
https://help.fitbit.com/#product_flex
Wendy | CA | Moto G6 Android
01-06-2014 18:26 - edited 01-06-2014 18:41
Thank you so much.
So, if I log something does that mess up what the Flex measured during the workout?
Best Answer01-19-2014 10:24
01-19-2014 10:24
I have had the same problem as has my wife. The band does seem to be the issue and the band is quite difficult to put on in a tight position. It would be very helpful if Fitbit coud offer a band which is easier to adjust - put on, etc. The current configuration is anything but easy to use!!
Cyril
Best Answer01-19-2014 10:41
01-19-2014 10:41
I agree. I don't find the band very easy to put on either. I have decided to use the journal to log all my activities. I have found that when logging on the activity page it will mess up what the flex recorded.
