08-11-2019 13:32
08-11-2019 13:32
Where do I check what my activity level is set at and how do I change it?
Best Answer08-11-2019 23:09
08-11-2019 23:09
In the mobile app, tap the "active minutes" symbol (looks like a flash). On the next screen, tap on the "cogged wheel" in the upper right corner. This will display your current activity goals, for steps, distance, calories, active minutes, floors (if supported), hourly activity goal. You can tap on any of these if you want to set your own (by default, they are set by Fitbit for you).
Dominique | Finland
