Hi all,
I have set myself a goal of walking 500 miles by june and 1000 miles by the end of the year.
Does anyone know of a way to set up such a goal in Fitbit or endomondo?
I have found a way to set such a goal in runkeeper but it does not include my fitbit data which makes it pointless downloading fitbit data to it.
I would like to see a running total of my miles walked so far ,how far i have to go etc
thanks
If you trust the Fitbit distance data (in which there's of course a lot of "noise", all these baby steps taken at home), you can import all your daily data in a Google spreadsheet using the script mentioned here. Once it's in a spreadsheet, you can manipulate the data to your heart's content, draw graphs etc. The script will let you sync the data from Fitbit automatically every day, so each time you open the sheet, you'll have the most up-to-date data. You can also sync manually.
Dominique | Finland
Best AnswerThank you for the information.
I'll have a play with it later ![]()
