10-07-2020 09:50
10-07-2020 09:50
I have a fitbit 3 and am just starting a cardio-rehab program. My consultant has advised that I increase my 40 minute walk to a twice a week doing a walk of about 10 minutes (starting slow and increasing my pace until I hit the 10 minute mark) I then need to move into the running phase of intervals of initially 1 minute run and 1-2 minutes walking recovery and finishing with a 10 minute walk getting slower.
As my fitbit has trouble connecting to my android phone (it can take a couple of tries) I'd rather not stop between each phase and try to select a different exercise program.
What is my best tracking option? (Walk or run or something else)
10-07-2020 16:32 - edited 10-08-2020 14:48
Hi @DavidPa
Given that you cannot easily start a new exercise record each time you change speeds, I would suggest just logging the whole 40 minutes as a run and then focusing on distance covered over 40 minutes as a metric of your progress over time. One benefit of using the "run" option, even if you don't really run all the time, is that fitbit will use your times to better estimate your cardio score (Fitbit's estimate of VO2 max). That's another metric that should improve over time as you actually run more and your cardio improves.
Scott | Baltimore MD
Hi @DavidPa
10-08-2020 11:03
10-08-2020 11:03
Scott,
Thank you for your reply. The choice and background for the reason is the sort of insight that I was hoping.
