This is more of a question about prefrences but how do people measure non walking activities (such as in my case weight training?)
I know that MyFitnessPal does have a section for strength training but I'm trying something a bit different and I'm not sure how accurate it is:
I take perscription stimulants for Narcolepsy and have been told to watch my heart rate when exercising (its fine btw, my neurologist is just super jumpy) and thought I'd employ the tracking function to find my activity calorie output. Thing is I know the tracker is calibrated for running so I'm not sure how accurate it is.
I *think* its ok as its basing the readings on my heart actvitiy but I have no idea if thats more or less accurate than taking a preset reading from a website.
Anyone else doing it this way or got any other ideas on how to get stationary exercise into fitbit?
I wear my Fitbit Zip on my shorts clipped to my left shorts pocket. I do several 30 minute recumbent bike sessions each day (yesterday about 2 hours and 10 minutes) and burned over 4,000 calories.
It appears that the Zip is picking up or treating my hip movement as forward motion. While I do over 30 miles on the bike, my mileage and step count on Fitbit dashboard is registered as less.
I also manually log my bike exercise each time just to make sure. I input calories as I get them automatically calcualted from my Under Armour Map My Fitness account.
I'm meeting my step, distance, VAM, mile, and calorie goals for each day, so it's working for me.
Best AnswerAlso, I find that I burn more calories "biking" in less time than I do walking. For instance, I burned over 4K calories in a little over 2 hours, yesterday.
I burned 4,301 calories walking/hiking back one day in late November but that was over 6 1/2 hours.
Best AnswerIf you work with a trainer, ask them how many calories you burn doing a certain exercise. My trainer tells me that I usually burn 211 calories doing the cardio workout with weights for 30 minutes, then I do the elliptical for 25 minutes. If you have an Iphone and are using My Fitness Pal you can syn in your workouts. It will also help you keep track of what your are eating. Congratulations on your healthy journey
@C0nt1nu1ty wrote:This is more of a question about prefrences but how do people measure non walking activities (such as in my case weight training?)
The Fitbit seeing a few steps during strength training and assigning a calorie count based on it is grossly under-estimated.
Log it in MFP as Strength Training in cardio section, it may seem low compared to cardio, but that is true.
On Fitbit, log as Weight training, power lifting if it was heavy for you and rests were 1-3 min only between sets, or if easly lifting just maintenance level, then easy level.
And no, heart activity for calorie burn estimates are based on formula's ONLY valid for aerobic exercise that is steady state same HR for 2-4 min. It's based on providing oxygen.
If you are somehow making weight training fit that bill - then you are doing it all wrong, as it should be anaerobic during lifts, and totally opposite of steady-state HR.
What Fitbit you using that is basing it on HR?
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
