So I'm trying to work through an ab challenge video every day. I've been burning at least 85 calories and logging these active moments (usually about 10-12 minutes) and I go back to check my calorie burn only to see that it has not changed from the number of calories burned before adding this activity. This is particularly disappointing especially when I really like to see all of my goals reached and surpassed by the end of the day.
Can anyone reflect on this?
@Ms_Canuck wrote:So I'm trying to work through an ab challenge video every day. I've been burning at least 85 calories and logging these active moments (usually about 10-12 minutes) and I go back to check my calorie burn only to see that it has not changed from the number of calories burned before adding this activity. This is particularly disappointing especially when I really like to see all of my goals reached and surpassed by the end of the day.
@Ms_CanuckFitbit has the bug when you create and edit manual data it defaults to Today and AM as @Jrdubyakc has posted about time. Also I find there is a delay sometimes after adding data and I do a refresh on the web browser after adding a manual record.
Also, are you referring to the Fitbit tracker calories or the Dashboard because you need to sync to have the manual data appear on the Fitbit.
We are definitely here to help and in a fortnight I'm 3 years with Fitbits and hopefully with our experience we can aid you in your new journey. Ironically I have never had a problem with the Fitbits I have chosen and you should get lasting fitness pleasure out of yours.
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
Sam | USA
