Compare the values per 100g NOT serving size. Each manufacturer gives a different serving size - often the smaller the serving the better the numbers look but realistically people will eat more than the so-called serving. Breakfast cereals are a case in point!
I'll usually just add the two items into separate categories (like one in "Afternoon snack" and the other under "Dinner") and see how they match up. Make sure you do it in the amount you would actually eat, not suggested serving size. Then I just delete whichever one (or both) that I don't eat.
I've only worked it that way on my PC, but it should work on the phone app as well.
