Best AnswerAt what speed were you jogging on the treadmill? Which Fitbit are you using?
The distance logged on the Fitbit - in my opinion - isn't entirely accurate. It is certainly a good guide and provides you with a target in the sense of walking/running farther today than you did yesterday.
As for the difference in readings between you Fitbit and the treadmill - we're talking about two machines. There is a margin of error on both counts.
With the account of you and your husband running side by side, stride for stride - that one has me baffled!
Best AnswerTreadmill more accurate.
That's why you adjust your stride length settings if you get inkling they aren't correct.
And your comments about comparing with husband walking.
Is that treadmill speed it sounds like, but your cadence or turn-over is the same. That's not surprising.
Height doesn't matter totaly of course, leg length, muscle for pushing, ect is what matters.
Also, you didn't give time of your little compare, so doing your math, is 1/2 correct or not. Sounds like both of your stride length measurements are off.
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
Best Answerhow do you adjust stride lengths?
My treadmill says I'm walking at least a half mile more than what the fitbit says.
@mkbc59 wrote:how do you adjust stride lengths?
Gave solution on your topic.
Best AnswerSorry about auto correct. I was saying . I have same problem
It will never match. Your stride is different on the treadmill than out side.
I just go with it. Its not off by that much to worry about.
Wendy | CA | Moto G6 Android
@Canaveralgal wrote:Sorry about auto correct. I was saying . I have same problem
Your treadmill, or at a gym?
Do you know when it last had the belt distance calibrated correctly, so you know you can trust it as accurate?
Is this for walking or running?
Because that is 2 different settings.
Walking stride-length is what your daily activity burn is based on.
You would not want it set to exercise level pace, nor on an incline on treadmill (Fitbit's can't determine if any incline) - or else then it would be more inaccurate for the vast majority of your daily movement.
