01-23-2014 10:42
01-23-2014 10:42
Does FitBit accurately track activities like Shoveling Snow? I spent the better part of 3 hours shoveling out after a major snow storm. When I checked my activity monitor, I was disappointed by calories burned. Could this be because it's mostly my upper body doing all the work?
01-23-2014 10:56
01-23-2014 10:56
No. There's no way Fitbit can know whether you are shoveling heavy wet snow or lighter powder snow, or even that you're shoveling anything at all. In fact, it will likely credit you with less calories than if you weren't shoveling anything, because you're probably moving more slowly when shoveling.
A heart rate monitor would best track the intensity of such an activity and calories burned performing it.
Dominique | Finland
01-23-2014 10:56
01-23-2014 10:56
Dominique | Finland
01-23-2014 11:46
01-23-2014 11:46
01-23-2014 12:19
01-23-2014 12:19
No, it doesn't count mopping or vacuuming, either. 😞
Best Answer01-24-2014 22:52
01-24-2014 22:52
I'm pretty sure it counts my mopping and vacuuming steps. There's not much resistance so I don't expect any more burn than any other puttering activity.
Best Answer01-27-2014 16:43
01-27-2014 16:43
Best Answer04-28-2014 18:58
04-28-2014 18:58
I clean my house with the Fitbit One and can rack up 7,000 steps in no time ! Shoveling snow too ! Snowblowing snow too !
@kneh13 wrote:Does FitBit accurately track activities like Shoveling Snow? I spent the better part of 3 hours shoveling out after a major snow storm. When I checked my activity monitor, I was disappointed by calories burned. Could this be because it's mostly my upper body doing all the work?
Best Answer06-13-2014 04:07
06-13-2014 04:07
it does count, but it underestimates. It counts it as steps, therefore your best chance is havng it on your foot or waist, not on your wrist (where it counts least accurate).
so any activity, like shoveling, raking leaves, vacuuming etc - it just counts it as steps calories.
and be careful with it - I lost one while shoveling.
Best Answer02-16-2015 17:43
02-16-2015 17:43
I accept that FitBit doesn't know the weight of the snow, the exertion you expend, but...
The activity is partially editable (the activity is editable). I for example went out and found a calculator that translates activity, weight, age, and time into calories. Acurate? Well, it is closer than the fitbit with its limited sensor set.
However, I should be able to edit the activity and say 'hey, this is weightlifting, moderate intensity' or 'shoveling snow' and the fitbit should either apply an algorythm to it or allow us to modify the caloric output from other calculators.
Personally, I use and eliptical, a treadmill, then lift weights -- I clock each seperately and for the treadmill I find it is accurate, the elliptical a little under (I use a lot of resistance), but my weightlifting is way under. That, is okay as I don't yet expect my device to actually measure caloric burn (soon though), yet I should be able to edit the three workouts and based on my time lifting set the burn accordingly
02-16-2015 22:24
02-16-2015 22:24
@BrodyB wrote:I accept that FitBit doesn't know the weight of the snow, the exertion you expend, but...
Well, instead of changing the Activity record - which not all devices support BTW from the device - you merely Log an activity workout (not record), and use the start duration time and use the calorie burn with the database entry.
Weights in in there, so is elliptical with intensity options.
So if you were going to rename an activity record, and select what activity type it was, and hit save.
Just hit Log activity, type in exercise type, and you have a couple of extra pieces of info to enter, and it'll do the calorie burn this time.
Best Answer02-17-2015 04:30
02-17-2015 04:30
Best Answer02-17-2015 04:31
02-17-2015 04:31
Best Answer01-18-2016 11:13 - edited 01-18-2016 11:19
I am truly amazed that fitbit removed snow shoveling from the activities list you could manually had I really think it should be added back. Huge calorie burn there that you cannot account for anymore. Maybe one of the moderators such as @MatthewFitbit or @EmersonFitbit can find an answer for. It used to be there because I still show it where I used to log it. I decided I better do a snapshot of the screen before anyone could say no they never had it.
01-21-2016 12:09
01-21-2016 12:09
I would always prefer an underestimate of calorie count over a inflated estimate for a specific activity. If you are monitoring the ins and outs based on the underestimate and still under then you know you've nailed the daily goal.
01-23-2016 12:03
01-23-2016 12:03
I agree - snow shoveling should be one of the trackable exercises! I did a rough calculation of the calories burned, and it seemed reasonably close to cross-country skiing so that's how I logged my time. But darn it, I was shoveling not skiing!
02-15-2016 08:36
02-15-2016 08:36
I found this website for calculating how many calories burned while shoveling snow. I guess I will be using this unless fitbit decides to add snow shoveling back as an activity!
https://www.fitday.com/webfit/burned/calories_burned_Shoveling_snow_by_hand.html
Best Answer02-15-2016 10:45
02-15-2016 10:45
02-16-2016 11:42
02-16-2016 11:42
