12-11-2013 13:58 - edited 12-11-2013 14:14
Has anyone else experienced problems with the force not counting steps and activity while on a treadmill. My husband usually holds on to the sides of the treadmill while walking. I have two bad knees and either hold on in front or alternating one hand in front and one to the side. I get a true count but he doesn't. Any ideas? Written by Kathy
Best Answer12-11-2013 14:18
12-11-2013 14:18
Yeah, I've noticed that too. I don't think your arms need to swing, but they need to feel the impact of your steps.
My solution was to put the thing in my pocket while I run on the treadmill, where it seems ot still be totally accurate.
12-11-2013 16:25
12-11-2013 16:25
someone on one of the other posts suggested making a small hole in a wristband and putting it in there and then putting it on you ankle...that seemed to work for the treadmill and bike....
Best Answer12-12-2013 08:23
12-12-2013 08:23
If all you care about is steps count, wearing a Flex on your ankle might work. But I can't imagine the movement of your ankle is otherwise much like the movement of your wrist as far as it signalling the device what speed/intensity you're walking. So I wouldn't trust the calorie measurement. It's programmed to use data collected while on the wrist.
12-12-2013 15:16
12-12-2013 15:16
If I need to hold on when on the treadmill, I use the hand opposite my Force. I do try to swing my other arm (with the Force) even when holding with one hand.
12-13-2013 18:04
12-13-2013 18:04
Good Suggestion!!
Best Answer12-15-2013 08:09
12-15-2013 08:09
I can't imagine using a force. I knit and crochet. Can you imagine what it would tell me with that?
Best Answer12-19-2013 20:28
12-19-2013 20:28
It would seem to work on the treadmill where the impact of your feet are counting your steps but on the bike you might be measuring just one leg movement, hence only half of the step count.
Best Answer12-19-2013 20:33
12-19-2013 20:33
Larry, I have always run or walked without holding on to also train balance. Have had zero problems with step counts.
