09-19-2022 23:51
09-19-2022 23:51
I'm wondering if this is normal. I was in Light sleep and my HR Reading dropped from a 66 to 46 at 4:11 and stayed at that exact reading for 5 minutes.
Best Answer09-19-2022 23:52
09-20-2022 17:02
09-20-2022 17:02
Hello @SunsetRunner
I tend to believe that the tracker lost contact with your wrist and had incorrect reading. My suggestion would be to keep checking and in case report similar cases.
Best Answer09-30-2022 07:36
09-30-2022 07:36
I would not take this lightly. You should contact your doctor and ask questions about sleep apnea. Even if you are very fit, it could be an issue for you.
