04-04-2017 17:49
04-04-2017 17:49
I found and fit bit in the onehunga Auckland area and would love to reunite it with its owner if you can private message me with where you lost it ... Or close to
Caio
Best Answer04-06-2017 03:47 - edited 04-06-2017 04:02
Being a person who lost a Fitbit in the past.
Here are two suggestions I have to help ensure it gets returned or found.
1. Add a message to you Fitbit "TAP DISPLAY" Screen message that is your contact Phone Number .
( located in your profile by clicking on your device and adding your number into the tap display message section). After that you have to put your trust in the honesty of others to reunite you with your lost Fitbit.
2. Load the Fitbit Finder App into you cell phone. Works great to help narrow down your search.
CC
Best Answer04-04-2017 18:14
04-04-2017 18:14
You can contact Fitbit and they may be able to help.
Best Answer04-05-2017 02:18
04-05-2017 02:18
Best Answer04-05-2017 12:03
04-05-2017 12:03
I don't know if this will work or not - BUT - can you sync the found Fitbit to your phone and then log an activity with it? I'm wondering if it will show up on the owner's dashboard/activity log. Then they could see where it is.
Of course, if this even works, I wouldn't suggest doing it from your home. But maybe a local coffee shop would be willing to hang a sign that says, "Are you here looking for your lost Fitbit? Ask for the manager." Then you could use that location to log workouts that may show up on owner's dashboard?
Just a thought. Good luck!
Best Answer04-05-2017 13:08
04-05-2017 13:08
Did you contact Fitbit? As they have reunited many lost fitbits with its owner. Sounds like you got the wrong Rep
Contact Support
http://help.fitbit.com/?cu=1
Wendy | CA | Moto G6 Android
CC
Best Answer04-08-2017 14:01
04-08-2017 14:01
Best Answer04-08-2017 14:03
04-08-2017 14:03
good idea , I had hoped being a small community that I would get a message or something but to date nothing .
Thanks will investigate further otherwise drop into the local police station
Best Answer04-08-2017 14:04
04-08-2017 14:04
Thanks 😀 Good suggestion
Best Answer04-08-2017 14:05
04-08-2017 14:05
Maybe I did I'll try again
