06-19-2019
19:35
13:49
GraceGFitbit
06-19-2019
19:35
13:49
GraceGFitbit
My Fitbit does not register mph, average mpg or distance after a bike ride. Am I doing something incorrect? It records everything else like heart rate, calories burned, etc.
Best Answer06-21-2019 10:22
06-21-2019 10:22
@qstv — make sure you have actually connected to your phone. (I.e., start a bike activity from your Versa, and wait until it indicates it has connected. Then, at the end of the ride, end the activity on the watch.
If you are also running Strava on your phone for the same ride (and have linked Strava with Fitbit) keep in mind that you will have two apps pulling GPS info (Fitbit and Strava). Both will run their own algorithms to calculate distance, speed, etc. They may report slightly different numbers.
@RossJones — yes, the Charge 2 has connected GPS. Have a look at the manual at about page 23 or so.
Hope that helps.
Scott | Baltimore MD
06-20-2019 03:18 - edited 06-20-2019 03:20
@qstv Are you using connected GPS during your bike ride (there are only some Fitbits that have this ability)? If you are not then the Fitbit will have no way to know how far youve gone or your speed.
Helen | Western Australia
06-20-2019 08:26
06-20-2019 08:26
Hello Nelly, thanks for your quick response. I'm using connected GPS on my Versa watch and carry along my mobile and use Strava to map my routes and speed. I'll try again today, maybe it was a glitch. Be safe out there.
Best Answer06-21-2019 07:05
06-21-2019 07:05
Does the Charge 2 have this capability if it is connected to an iPhone?
06-21-2019 10:22
Hope that helps.
06-21-2019 10:32
06-21-2019 10:32
Best Answer06-23-2019 13:50
06-23-2019 13:50
@qstv .. that's great- so pleased you are up and running. If Nelly or Scott helped answer your question, consider marking their reply as a solution to help others find the answer in a similar situation.
Elena | Pennsylvania
Best Answer05-30-2020 13:51
05-30-2020 13:51
I have the same problem. GPS is connected, I get mph and distance if inhave my android phone unlocked with the fitbit app open. Once I lock my phone and put it in my pocket it stops tracking data. Why??
Best Answer06-01-2020 07:38
06-01-2020 07:38
That is phone dependant - some stop the GPS when locked - they figure you must not be using it if you just turned the screen off and locked it.
If you use Google maps (on android) and have it going on some directions somewhere, and lock the phone the same way - does it keep working?
Like when you unlock to view the map does it have you instantly on at the correct spot on the map, or does it have to update first and move the map around?
Search phone forums to see if there is a way around it - some Android phones allowing going into a developer mode settings - and you'll find settings such as that you can enable.
Best Answer06-01-2020 08:53
06-01-2020 08:53
